Airzone integration: Add support for the consumption meter device
Hi, I make use of the excellent Airzone integration.
I have the Airzone consumption meter in the system (AZX6ACCCON), however this device and its data is not shown at all in the Airzone integration. Would it be possible to add this to the integration?
@rjnl the problem with the Airzone consumption meter is that it only reports the data consumed in the last hour, it doesn’t provide an accumulated value of the power consumption, so in order to support it I guess that we would have to accumulate that value ourselves, which isn’t trivial since we don’t know when the value has been updated…
Ideally Airzone should provide an accumulated value to be able to use it on Home Assistant or otherwise the value will not be accurate at all…
Also looking for this feature.
We can try to debug and code a meter that adds values automatically.
Also I am sure Airzone would be open minded to add a new api output value if they can!
