I want to hear more about this when you finalized the setup! Maybe even write a blog post how to install/configure all components to make this work.
Yesterday I installed this custom component: https://github.com/Cheaterdev/sia-ha
This works perfectly for me! You would not need to use an MQTT broker anymore, it is directly catched in the custom component in HA.
You could alter the init script (reactions list) to suit your needs based on the SIA codes coming from the Ajax hub.
I too am looking at AJAX as a security means for my house. Since I want to start using Hass.io, I came across this topic. Isn’t this custom component using the CMS feature of AJAX? https://support.ajax.systems/en-us/article/327-how-to-use-the-sia-protocol-to-connect-the-hub-to-the-central-monitoring-station
I was wondering wether or not you still don’t want it to update your MQTT broker, since then you can subscribe multiple components to it (e.g. Hue lightning etc etc)
Hi Sander
Please confirm if this was also with use of the Ajax alarm system? Hoping to do the same.
I can confirm that the sia-ha component works with ajax.
I have been testing it my self and added a line of code in the init__.py to handle the reset of tamper alarm, but I have written to the guy at github also, so I hope he will add it in his project.
but it really works nice
Hi Allan,
I have just purchased the Ajax Alarm System, and I am running the latest HA version (096.3). I am however getting the following in my logs:
2019-07-22 21:44:17 INFO (MainThread) [homeassistant.setup] Setting up sia
2019-07-22 21:44:17 ERROR (MainThread) [homeassistant.setup] Error during setup of component sia
File “/Users/moodiejo/.homeassistant/custom_components/sia/init.py”, line 83, in setup
File “/Users/moodiejo/.homeassistant/custom_components/sia/init.py”, line 160, in init
Any idea on this for me please?
I do realise that you are not the developer of this custom component, but any help will be truly appreciated.
Thanks you in advance.
John Moodie
Anybody who has solved the SIA integration when having more than one Zone? I have written about it in this issue tracker for SIA-HA by Cheaterdev: https://github.com/Cheaterdev/sia-ha/issues/4#issuecomment-514727373
The problem is that when having more than one zone you get unknown SIA codes. Even though I have figured out what they represent, this means that the SIA integration is unusable for anybody with more than one alarm zone. We need to be able to identify which zone is armed and which is not…
Hi John
At first, I added the custom_components folder in the config folder, not sure if it makes a difference but thats how I read it should be.
Do you use encryption on your sia connection?, I don’t, maybe that also can cause an error
Hi Allan,
Thank you for replying.
I don’t use encryption, even though the error seems to be encryption related, possibly even a python library. See further below for a full stack trace. I will scratch more on the python side and see what I can find.
The ‘sia’ folder has been added to my custom_components folder, where I also run other custom components.
File “/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/homeassistant/setup.py”, line 156, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
hass.data[DOMAIN][hub_config[CONF_ACCOUNT]] = EncryptedHub(hass, hub_config)
_cipher = AES.new(self._key, AES.MODE_CBC, iv)
File “/Users/moodiejo/.homeassistant/deps/lib/python/site-packages/Crypto/Cipher/AES.py”, line 232, in new
return _create_cipher(sys.modules[name], key, mode, *args, **kwargs)
File “/Users/moodiejo/.homeassistant/deps/lib/python/site-packages/Crypto/Cipher/init.py”, line 79, in _create_cipher
return modes[mode](factory, **kwargs)
File “/Users/moodiejo/.homeassistant/deps/lib/python/site-packages/Crypto/Cipher/_mode_cbc.py”, line 274, in _create_cbc_cipher
cipher_state = factory._create_base_cipher(kwargs)
File “/Users/moodiejo/.homeassistant/deps/lib/python/site-packages/Crypto/Cipher/AES.py”, line 93, in _create_base_cipher
raise ValueError(“Incorrect AES key length (%d bytes)” % len(key))
ValueError: Incorrect AES key length (15 bytes)
Issue bypassed - I removed the password parameter in my configuration.yaml, but am also now getting the Unknown Events as reported earlier.
Well I solved it myself. I have two zones and this worked for me. Used IObroker to find out what the SIA codes looked like and included the zone part in sia-ha.
I changed the init.py code to include the zone part and changed and added reactions as well as sensors to all of them. Would of course be better to dynamically include additional zones or to be able to define how many you have somewhere. But for those of you that are running two zones you can use the below code in your “init.py” file.
class Hub:
reactions = {
"Nri1/BA" : [{"state":"ALARM_ZONE1","value":True}],
"Nri1/TA" : [{"state":"ALARM_ZONE1" ,"value":True}],
"Nri1/CG" : [{"state":"STATUS_ZONE1" ,"value":False},{"state":"STATUS_NIGHT_MODE" ,"value":False}],
"Nri1/CL" : [{"state":"STATUS_ZONE1" ,"value":False},{"state":"STATUS_NIGHT_MODE" ,"value":False}],
"Nri1/NL" : [{"state":"STATUS_NIGHT_MODE" ,"value":False}],
"Nri1/NP" : [{"state":"STATUS_NIGHT_MODE" ,"value":True}],
"Nri1/WA": [{"state":"LEAK_ZONE1","value":True}],
"Nri1/WH": [{"state":"LEAK_ZONE1" ,"value":False}],
"Nri1/GA": [{"state":"GAS_ZONE1","value":True}],
"Nri1/GH": [{"state":"GAS_ZONE1" ,"value":False}],
"Nri1/BR" : [{"state":"ALARM_ZONE1","value":False}],
"Nri1/OG" : [{"state":"STATUS_ZONE1","value":True},{"state":"STATUS_NIGHT_MODE","value":True}],
"Nri1/OP" : [{"state":"STATUS_ZONE1","value":True},{"state":"STATUS_NIGHT_MODE","value":True}],
"Nri2/BA" : [{"state":"ALARM_ZONE2","value":True}],
"Nri2/TA" : [{"state":"ALARM_ZONE2" ,"value":True}],
"Nri2/CG" : [{"state":"STATUS_ZONE2" ,"value":False}],
"Nri2/CL" : [{"state":"STATUS_ZONE2" ,"value":False}],
"Nri2/WA": [{"state":"LEAK_ZONE2","value":True}],
"Nri2/WH": [{"state":"LEAK_ZONE2" ,"value":False}],
"Nri2/GA": [{"state":"GAS_ZONE2","value":True}],
"Nri2/GH": [{"state":"GAS_ZONE2" ,"value":False}],
"Nri2/BR" : [{"state":"ALARM_ZONE2","value":False}],
"Nri2/OG" : [{"state":"STATUS_ZONE2","value":True}],
"Nri2/OP" : [{"state":"STATUS_ZONE2","value":True}],
"Nri0/RP" : []
def __init__(self, hass, hub_config):
self._name = hub_config[CONF_NAME]
self._accountId = hub_config[CONF_ACCOUNT]
self._hass = hass
self._states = {}
self._states["LEAK_ZONE1"] = SIABinarySensor("sia_leak_zone1_" + self._name,"moisture" , hass)
self._states["GAS_ZONE1"] = SIABinarySensor("sia_gas_zone1_" + self._name,"smoke", hass)
self._states["ALARM_ZONE1"] = SIABinarySensor("sia_alarm_zone1_" + self._name,"safety", hass)
self._states["STATUS_ZONE1"] = SIABinarySensor("sia_status_zone1_" + self._name, "lock", hass)
self._states["STATUS_NIGHT_MODE"] = SIABinarySensor("sia_status_night_mode_" + self._name, "lock", hass)
self._states["LEAK_ZONE2"] = SIABinarySensor("sia_leak_zone2_" + self._name,"moisture" , hass)
self._states["GAS_ZONE2"] = SIABinarySensor("sia_gas_zone2_" + self._name,"smoke", hass)
self._states["ALARM_ZONE2"] = SIABinarySensor("sia_alarm_zone2_" + self._name,"safety", hass)
self._states["STATUS_ZONE2"] = SIABinarySensor("sia_status_zone2_" + self._name, "lock", hass)
def manage_string(self, msg):
_LOGGER.debug("manage_string: " + msg)
pos = msg.find('/')
assert pos>=0, "Can't find '/', message is possibly encrypted"
# tipo = msg[pos+1:pos+3]
tipo = msg[pos-4:pos+3]
Edit: In order for the alarm status to be reset to safe/normal after a triggered alarm has been deactivated you need to add the TR code. Otherwise the alarm status will always show “unsafe”.
"Nri1/TR" : [{"state":"ALARM_ZONE1" ,"value":False}],
"Nri2/TR" : [{"state":"ALARM_ZONE2" ,"value":False}],
does it require any specific components in your ajax system or is it just the Hub (not even the Hub Plus) connected into your network?
You just have to set up the SIA Protocol in the Ajax App. You define which IP your HA server is on and then set a port that is not used for anything else (I used 8124). The Ping interval should be set to 1 minute and with connect on demand enabled. Then you download CheaterDev’s repository and add the sia integration in the configuration.yaml file.
The only thing I had trouble with was the encryption password which only may contain up to 32 HEX or 16 ASCII characters. It took a shile to figure out that it was the password that was not formatted correctly. This is explained here:
thanks for the extensive writeup! much appreciated, will order my Ajax system soon! And the component is purely Ajax -> HA (one-way) and not two-way correct (although the protocol could do two-way presumably)?
Yes, only one way. I use it purely for reading the status of the alarm and to automate things based on that.
If you want two way for the possibility to arm and disarm the alarm there is no Ajax supported solution. You could achieve it by stripping an Ajax SpaceControl remote and solder it to a remote controlled relay. For example a Sonoff or similar and then connect that to HA. But you need to understand the security implications of doing this.
Wait what!? Are you saying that without any additional hardware I can read the Ajax alarm status in HA? If so this is amazing! I love my Ajax alarm but wish I could get the status in HA (armed, disarmed, intrution detected). Are these three states the ones that you get and it is updated every minute?
Edit:
I have been in contact with Ajax and IFTTT is something they are working on (again) so that will hopefully be amazng too.
yes, the code needed is made by CheaterDev and can be downloaded from here:
All SIA codes supported by the SIA protocol can potentially be used. CheaterDev has not developed for all of them but fire, leak and burglar alarm status works. And if the alarm is armed or not.
Also, see my modified code in the posts above to get support for multiple zones and especially the TR code which is needed to properly reset the alarm state after a triggered alarm.
Amazing! Thanks! I don’t have Home Assistant yet so just needed to be sure I understood this correct
The only thing you have to do it type in the IP address and the port on Ajax HUB of your homeassistant so Ajax connects to HomeAssistant as a control central.
yeah that is perfect, I don’t want my alarm system controlled by HA exactly because of security considerations, just want to read status. And my system should arrive today!
