That’s great! Definitely a good reponse from Ajax after a while. (Already did it but without reponses)
With my latest message, it confirm that Ajax would like separate Pro products and end-user products.
For the moment, wouldn’t it work just to dismantle an AJAX Space Control fob, for the purpose of soldering (for example) a zigbee switch to the internal buttons so the alarm can be at least armed and disarmed through an automation? Together with the integration that monitors the alarm state only, I think some sort of control from HASS would be possible. I know it is not the cleanest solution but it could work. Couldn’t it?
This is exactly what some of us have done, see Controlling Ajax. As for me I use 3 relays of a relay board that is connected to ethernet.
Here you can vote for HA integration
Not related to Ajax API.
you can join on my project… i’m working on it!
@Den901 Looking forward to your progress on the AJAX API integration.
What kind of support do you need to get things moving?
As an AJAX supplier/installer, I’m able to get an API key if you’re still missing out on that. If you need someone to test, I can support you with that as well.
Hi! I have to finish the manager on github and then we can integrate it…
For now u can use a simple nodered flow
