Pessoal
Segui esse tutorial https://medium.com/@thejeffreystone/home-assistant-and-cloudflare-e125338f60ad mais não deu certo, alguem pode me ajudar?
Pessoal
Could you be more specific on what’s your issue?
I am using HA with Cloudflare. However I am not using the SSL certificate provided by Cloudflare.
I am not sure and I never tried, but I have lot of subdomains so I am not quite sure if the SSL certificate provided will do the trick. Either way I needed the NGINX Reverse Proxy to be able to serve all of these subdomains, since NGINX comes with LetsEncrypt it’s almost dumb-proof. You don’t really have to worry about the SSL certificates.
Consegui usar o SSL da Cloudflare com Home Assistent amigo.
Muito obrigado pela ajuda, consegui usar com subdominio tambem
