in your config.yaml
rest_command:
example_request:
url: "http://IP-ADRESDOOR/fcgi/do?action=OpenDoor&UserName=X&Password=X&DoorNum=1"
change X by password and username of your login of your akuvox doorbell.
This is the code to open a door
so in an automation this gives you:
action: rest_command.example_request
data: {}
when pressing the call button you can use this
trigger: webhook
allowed_methods:
- POST
- PUT
- GET
- HEAD
local_only: true
webhook_id: akuvox_doorbell
therefor you have to put this in config yaml
webhook_service:
webhook:
this post Door Intercom - Akuvox R20K (on Ethernet) - #16 by GeryDk gives you more info about the akuvox part
If you want a badge system, you have to add your rfid code in the akuvoxx system and use this code to use the badge
webhook_id: akuvox_doorbell_validcard=049048A64F14566
