Automation I made to open the door . Where I can made actions to the person who is logging in…
Where’s the Webhook ID?
Does the yaml code stand completely as written above in automation? I’m new to Home Assistant.
Can you describe all the steps to create? What has to go where?
In my akuvox doorbell, but I don’t have acces to that right now
in your config.yaml
rest_command:
example_request:
url: "http://IP-ADRESDOOR/fcgi/do?action=OpenDoor&UserName=X&Password=X&DoorNum=1"
change X by password and username of your login of your akuvox doorbell.
This is the code to open a door
so in an automation this gives you:
action: rest_command.example_request
data: {}
when pressing the call button you can use this
trigger: webhook
allowed_methods:
- POST
- PUT
- GET
- HEAD
local_only: true
webhook_id: akuvox_doorbell
therefor you have to put this in config yaml
webhook_service:
webhook:
this post Door Intercom - Akuvox R20K (on Ethernet) - #16 by GeryDk gives you more info about the akuvox part
If you want a badge system, you have to add your rfid code in the akuvoxx system and use this code to use the badge
webhook_id: akuvox_doorbell_validcard=049048A64F14566
I just can’t get it.
In the configuration.yaml I have entered the following.
and in automation, the following is:
If I want to save the automation, there’s an error message. What am I doing wrong.
What’s that entity?
entity_id: counter.aanwezigheid
You dont need that if else structure. It is to test of somebody is already in the house
Did you also add webhook: in config.yaml ?
This is in the configuration.yaml:
And that’s the code for the dashboard
There is the integration of Akuvox, which I installed according to instructions. I see the door camera, but the door opening button doesn’t work.
This is the Logfile from Akuvox-Integration
personal door log
2024-12-19 15:11:38.520 DEBUG (MainThread) [custom_components.akuvox] Switching API address from 'single' to 'community'
2024-12-19 15:11:38.603 ERROR (MainThread) [custom_components.akuvox] ❌ Unable to retrieve user's personal door log
2024-12-19 15:11:40.688 DEBUG (MainThread) [custom_components.akuvox] Switching API address from 'community' to 'single'
2024-12-19 15:11:40.777 ERROR (MainThread) [custom_components.akuvox] ❌ Unable to retrieve user's personal door log
2024-12-19 15:11:42.866 DEBUG (MainThread) [custom_components.akuvox] Switching API address from 'single' to 'community'
2024-12-19 15:11:42.952 ERROR (MainThread) [custom_components.akuvox] ❌ Unable to retrieve user's personal door log
2024-12-19 15:11:45.044 DEBUG (MainThread) [custom_components.akuvox] Switching API address from 'community' to 'single'
2024-12-19 15:11:45.128 ERROR (MainThread) [custom_components.akuvox] ❌ Unable to retrieve user's personal door log
The trigger is an automation. Not in your config file
What’s automation doing?
Hi
In the list of countries India is not there
How to add India country code +91
Hi I tried to login with the token followed your manual. but unfortunately I don’t get the token and auth token or password. See underneath screen…
any help on this…
How do i connect mitmproxy?
Hi Everyone.
Recently jumped onto the Akuvox bandwagon from dahua land and just doing the last few bits to close off this chapter
Has anyone got a decent how to on getting the tokens to get the app into home assistant. for some reason i cant do the sms login (Australian user) to get this working. the use of the HTTP proxy is confusing me a touch
It’s seems that in the beta version v0.2.0-beta3 everything is working as should, the tokens extracted automatically and I can use both my phone app and HA.
@Nimrod_Dolev do you plan to release this beta soon?
I am having the same issue. I cannot log in using the mobile login for some reason (Australian user), and when intercepting the server_list requests, there is no body with Token or AuthToken. I’ve tried bypassing SSL pinning but no luck getting that working, so I’m unsure how to proceed.
It looks like the mobile app has updated it’s login API to 6.8 and no longer seems to POST a JSON body. You can see the token when listening to requests on your app, but I have no idea how to get the auth_token. This integration won’t work until a new way to log in is figured out.
I emailed Akuvox support but I don’t think there will be an easy solution here. The Akuvox documentation doesn’t have an obvious way to get those credentials either.
Hi everyone. The SmartPlus API has changed recently, so I have updated the instructions in the repository’s README for obtaining your auth_token and token values.
Please review the updated instructions and let me know if you can now sign in successfully when adding the integration ![]()
