Not sure when it happened(running latest HA release) but the Aladdin Connect integration dont seem to be working correctly since last update. The door will not see “closed” state after door is open/closed HA thinks its still open even though it is closed. oddly it detects open as normal. anyone else noticing this?
Yep. Started noticing this after 2023.2. The state won’t update till a long time after closing or opening. There was a dependency bump to Aladdin connect so perhaps that caused it. Might create an issue if it persists.
Yes I am having the same issue with 2023.2.3
Note this was fixed in 2023.3.5
