what is the easiest way to do that?
I know templates but it is a huge work for a simple task especially if you have many covers
template:
- binary_sensor:
- name: "covers Alarmo"
state: "{{ is_state('cover.open_cover', 'opened') }}"
state: "{{ is_state('cover.close_cover', 'closed') }}"
device_class: window
is this right?
No it is not. Only one state
option per binary sensor is allowed and the state of the entity is incorrect. Try this:
template:
- binary_sensor:
state: "{{ is_state('cover.open_cover', 'open') }}"
thanks a lot… I have 5 covers will this work as a generic for all of them or such I change the - name: “covers Alarmo”. to each cover speratly?
You will need to create a binary sensor for each cover.
template:
- binary_sensor:
- name: "covers Alarmo 1"
state: "{{ is_state('cover.open_cover_1', 'open') }}"
- name: "covers Alarmo 2"
state: "{{ is_state('cover.open_cover_2', 'open') }}"
- name: # etc...
Copy and paste should make light work of it.
on a previous code on the state was “opened”. not “open” also I renamed the name to show the open close
To know for sure, the only place you can check the real state that is not “translated” by the front end to look pretty is Developer Tools → States
that was very helpful
