Alarm Clock with Sonos
Hey Guys,
i have set up some automations which are used for my sonos system as an alarm clock.
Pre configured sonos alarms where created in the sonos app and are enabled and disabled via home assistant.
I use a spotify playlist here with a random song and 10 minutes before the alarm lights start to fade in.
This works great but i have some problem with the ressurence of the alarm.
Most of them are only weekdays and one alarm is daily. The daily one is used for weekends.
But now i only want one (or two) alarms in the sonos app which should be enabled or disabled by a weekday/weekend switch in home assistant. I want to reduce the amount of alarms in the sonos app because there cant be two alarms with the same time which can lead to errors. Is this possible or should i go with an media.play automation instead of the pre built alarm clocks in the sonos app?
Any one had experience with this?
