Hello all,
This almost appears to be a bug but let me try here first
I setup a manual alarm component and it appears to work without a code set. However now,
It appears that If a add a code to the alarm, I get the following in the logs:
Invalid code given for armed_home
or
Invalid code given for armed_away
Depending on what I pick
I have tried to fix this issue by trying the code with and without quotes (") for code.
I have tried using the code in secerts.yaml and directly in the config yaml. I have also tried the manual alarm and the manual alarm with mqtt (examples below)
alarm_control_panel:
platform: manual
code: !secret alarm_code
pending_time: 60
trigger_time: 60
disarm_after_trigger: false
- platform: manual_mqtt
state_topic: home/alarm
command_topic: home/alarm/set
pending_time: 30
delay_time: 20
trigger_time: 4
code: “9999”
disarmed:
trigger_time: 0
armed_home:
pending_time: 0
delay_time: 0
triggered:
pending_time: 0
To be clear, I see the code number panel in the alarm card but It just is not working for me.
I am using a docker install for homeassistant (not hass.io) on 0.93.1
Any ideas on what I can do?
