Home Assistant
0.47.1
Path to configuration.yaml: /Users/cwick/.homeassistant
Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: server — frontend-ui
Built using Python 3, Polymer 1.8.1, Icons by Google and MaterialDesignIcons.com.
The following errors have been logged this session:
2017-06-29 16:44:41 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-06-29 16:44:41 WARNING (MainThread) [homeassistant.setup] Setup of alarm_control_panel is taking over 10 seconds.
2017-06-29 16:44:41 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2017-06-29 16:44:42 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-06-29 16:44:42 WARNING (MainThread) [homeassistant.setup] Setup of remote is taking over 10 seconds.
2017-06-29 16:44:45 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-06-29 16:44:53 ERROR (MainThread) [pyalarmdotcom.pyalarmdotcom] Can not get login page from Alarm.com
2017-06-29 16:44:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/tasks.py", line 179, in _step
result = coro.send(None)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 368, in async_process_entity
new_entity, self, update_before_add=update_before_add
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 225, in async_add_entity
yield from entity.async_update_ha_state()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 238, in async_update_ha_state
state = self.state
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/alarm_control_panel/alarmdotcom.py", line 89, in state
if self._alarm.state.lower() == 'disarmed':
AttributeError: 'NoneType' object has no attribute 'lower'
Having the exact same issue. You have any luck resolving it?
@teknic90 Nope. I’ve tried updating the pyalarmdotcom package, I’ve completely uninstalled and reinstalled Home Assistant (kept yaml config files). Nothing seems to work.
@fabaff are you able to provide any assistance to myself and @teknic90? I’ve exhausted my resources for trying to resolve it. It really is a pain because i have my house setup to auto arm/dismarm based on user locations.
The integration is based on a grabber and it could be that Alarm.com changed something.
What you could do is output the result from def async_update(self):
in the alarmdotcom.py
file.
