I am using an alarmdecoder alarm panel and everything is working in the lovelace front end, however when I try to call the alarm_control_panel.alarm_arm_home service it does nothing.
Ultimately I am trying to put the arming of the panel into a script. But I cant even get it to set with calling the service.
This is the script I am trying to use and it seems to do nothing as well. The only way I can arm it is if I use the lovlace card
I’ve been told this is wrong, however if I change it to what people on here suggest it crashes my GUI… so what I have which does work (modified for your version):
So all I changed is the entity_id, to ‘all’. As I said I was told this is wrong by forum members but if I try using 'alarm_control_panel.alarm_panel', my system passes the config check but the GUI crashes (only when viewing remotely for some reason). Give it a try and see if it works for you…
It looks like if I put my code in quotations it works.
I have baffling behavior with the entity_id in my usage of this service call see home-assistant/issues/28633, but maybe what you have uncovered is a piece of this interconnecting puzzle.
