Alarmclock sunrise with music and summary with open ia
Hi all,
I created an alarmclock with use of different scrips and 1 automation.
As i’am still a beginner and trying to learn I was thinking maybe some one can take a look help me streamline it a bit more or help me to make it more reliable.
alias: Wekker Met Muziek En Overzicht Van De Dag
description: ""
  - platform: time
    at: input_datetime.wekker
condition:
  - condition: or
    conditions:
      - condition: state
        entity_id: binary_sensor.bed_bezet_deur
        state: "on"
      - condition: state
        entity_id: binary_sensor.bed_bezet_kast
        state: "on"
    enabled: true
  - condition: or
    conditions:
      - condition: state
        entity_id: input_boolean.weekend_wekker
        state: "on"
      - condition: state
        entity_id: input_boolean.vakantie_wekker
        state: "on"
      - condition: state
        entity_id: binary_sensor.werkdagen
        state: "on"
    enabled: true
  - service: switch.turn_off
    data: {}
      entity_id:
        - switch.adaptive_lighting_slaapkamer_verlichting
        - switch.adaptive_lighting_sleep_mode_slaapkamer_verlichting
        - switch.adaptive_lighting_adapt_color_slaapkamer_verlichting
        - switch.adaptive_lighting_adapt_brightness_slaapkamer_verlichting
  - service: media_player.volume_set
      volume_level: 0
      entity_id: media_player.slaapkamer_apple_homepod_mini
    enabled: true
  - service: media_player.play_media
      media_content_id: >-
        media-source://media_source/local/Muziek/Sounds Of Nature - Amazon
        Rainforest - Anton Hughes.mp3
      media_content_type: audio/mpeg
    metadata:
      title: Sounds Of Nature - Amazon Rainforest - Anton Hughes.mp3
      thumbnail: null
      media_class: music
      children_media_class: null
      navigateIds:
        - media_content_type: app
          media_content_id: media-source://media_source
        - media_content_type: ""
          media_content_id: media-source://media_source/local/Muziek
    enabled: true
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - parallel:
      - service: script.1688551121988
          lampBrightnessScale: zeroToOneHundred
          easingTypeInput: auto
          endBrightnessPercent: 42
          endBrightnessEntityScale: zeroToOneHundred
          minimumStepDelayInMilliseconds: 120
          isDebugMode: false
          light: light.slaapkamer_verlichting
          transitionTime:
            hours: 0
            minutes: 20
            seconds: 0
          autoCancelThreshold: 10
      - service: script.wakker_met_muziek
          target_volume: 0.36
          curve: logarithmic
          target_player: media_player.slaapkamer_apple_homepod_mini
          duration: 1200
        enabled: true
  - delay:
      hours: 0
      minutes: 20
      seconds: 0
      milliseconds: 0
  - service: switch.turn_on
    data: {}
      entity_id:
  - service: automation.trigger
      skip_condition: true
      entity_id: automation.new_automation1
mode: queued
max: 10
Hopefully somebody can share some tips and tricks, now it happens sometime that the light won’t come on or the music wordt start with the morning announcement
the first script : Ashley’s Light Fader
          isDebugMode: false
          transitionTime:
            hours: 0
            minutes: 20
            seconds: 0
the second script:
alias: Wakker Worden Met Muziek
mode: restart
fields:
  target_player:
    name: Target media player
    description: Target media player of volume fade.
    required: true
    example: media_player.slaapkamer_apple_tv
    selector:
      entity:
        domain: media_player
  target_volume:
    description: Volume the media play will be at the end of the fade duration.
    required: true
    default: 0.4
    example: "0.5"
    selector:
      number:
        max: 1
        min: 0
        step: 0.01
        mode: slider
  duration:
    description: Length of time in seconds the fade should take.
    required: true
    default: 20
    example: "5"
    selector:
      number:
        mode: box
        min: 0
        max: 100000
        unit_of_measurement: s
  curve:
    name: Fade curve algorithm
    description: Shape of the fade curve to apply.
    required: true
    default: logarithmic
    example: logarithmic
    selector:
      select:
        options:
          - logarithmic
          - bezier
          - linear
variables:
  steps_per_second: 10
  total_steps: "{{ (steps_per_second * duration) | int(0) }}"
  start_volume: "{{ state_attr(target_player, 'volume_level') | float(0) }}"
  start_diff: "{{ (target_volume - start_volume) | float(0) }}"
sequence:
  - repeat:
      while:
        - condition: template
          value_template: "{{ repeat.index < total_steps }}"
          value_template: >-
            {{ ((state_attr(target_player, "volume_level") - target_volume) |
            abs) > 0.001 }}
      sequence:
          data_template:
            entity_id: "{{ target_player }}"
            volume_level: >
              {% set t = repeat.index / total_steps %} {% if curve ==
              'logarithmic' %}
                {{ (start_volume + (t / (1 + (1 - t))) * start_diff) | float(0) }}
              {% elif curve == 'bezier' %}
                {{ (start_volume + (t * t * (3 - 2 * t)) * start_diff) | float(0) }}
              {% else %}
                {{ (start_volume + t * start_diff) | float(0) }}
              {% endif %}
        - delay: "00:00:00.5"
    data_template:
      volume_level: "{{ target_volume }}"
icon: mdi:tune-vertical
Last automation that is triggered at the end.
this is a modified automation from Allen’s notify-agent-agenda.
name: Conversation agent agenda notification
description: Conversation agent generates a notification based on the upcoming calendar
agenda, location, and weather.
author: allenporter
domain: automation
input:
notify_time:
description: Time the automation is triggered to send the notification.
selector:
time: {}
default: 07:00:00
notify_service:
name: Notify service name
description: The name of the notify service where the notification should be
sent.
selector:
text: {}
default: tts.cloud_say
calendar_entity:
description: The calendar entity to use for finding upcoming calendar events.
selector:
entity:
multiple: false
filter:
- domain:
- calendar
calendar_duration:
name: Calendar event duration
description: How many hours ahead to look for upcoming calendar events.
selector:
duration: {}
default:
hours: 18
weather_entity:
description: The weather entity to use for upcoming weather forecast.
selector:
entity:
multiple: false
filter:
- domain:
- weather
zone_entity:
name: Home zone entity
description: The zone entity to use to determine approximate location for understanding
typical weather.
selector:
entity:
multiple: false
filter:
- domain:
- zone
conversation_agent:
description: 'The conversation agent to use for generating the notification
text.
This should be a OpenAI conversation agent for this Blueprint to work.'
selector:
conversation_agent: {}
prompt:
name: Conversation agent prompt
selector:
text:
multiline: true
type: text
default: "Please generate text for a notification that will be sent to the users\nsmartphone
with helpful information.\n\nYou are a helpful personal agent that generates
text for the user:\n- Your answers are helpful, friendly, warm, insightful.\n-
Your answers are not technical, and do not include Home Assistant internal
details such as entities in responses.\n- Your messages help the user prepare
for their day, for example:\n - Making note of unusual weather for the location
and time of year (but not mundane details like \"0% chance of precipitation\")\n
\ - How much time remaining until their first meeting\n - Anything that may
be special or unique, such as celebrating a birthday"
source_url: https://www.home-assistant.io/blueprints/blog/2023-07/notify_agent_agenda.yaml
platform: time
at: !input notify_time
- variables:
weather_entity: !input weather_entity
calendar_entity: !input calendar_entity
zone_entity: !input zone_entity
calendar_duration: !input calendar_duration
prompt: !input prompt
- alias: Fetch Calendar Agenda
service: calendar.list_events
entity_id: !input calendar_entity
response_variable: agenda
- alias: Conversation Agent Notification Text
service: conversation.process
text: "Time: {{ now() }}\n{%- if zone_entity is defined %}\nLatitude: {{ state_attr(zone_entity,
'latitude') | round(1) }}\nLongitude: {{ state_attr(zone_entity, 'longitude')
| round(1) }}\n{% endif %}\n\n{%- if weather_entity is defined %}\n{%- set forecast
= state_attr(weather_entity, 'forecast')[0] %}\n{%- set temperature_unit = state_attr(weather_entity,
'temperature_unit') -%}\nWeather: {{ forecast.condition }} ({{ forecast.temperature
}}{{ temperature_unit }}, {{ forecast.precipitation }}% precipitation)\n{%-
endif %}\n\nCalendar \"{{ state_attr(calendar_entity, 'friendly_name') }}\"
events for the next {{ calendar_duration.hours }}:\n{%- if agenda.events %}\n
\ {%- for event in agenda.events %}\n - Summary: {{ event.summary }}\n Start-End:
{% if event.start is defined %}{{ event.start }} to {{ event.end }}{% else %}All
Day{% endif %}\n {%- if event.descripton is defined %}\n Descripton: {{
event.descripton }}\n {% endif -%}\n {%- if event.location is defined
%}\n Location: {{ event.location }}\n {% endif -%}\n {%- endfor %}\n{%-
else %}\n - No upcoming events.\n{%- endif %}\n\n{{ prompt }}"
agent_id: !input conversation_agent
response_variable: agent
- alias: Send notification
service: !input notify_service
message: '{{ agent.response.speech.plain.speech }}'
