Hello everyone, I am new to HA and I would like to know the procedure to connect the Verisure alarm to HA. I’m stuck on credentials with an “Invalid Authentication” message. Can you help me? Thanks in advance.
I’m not sure I can help you a lot but would you mind sharing your country?
I am facing the same issue (in France) and what I gather from the integration bug tracker is that the issue stems from the fact that depending on the countries, Verisure doesn’t always use the same element as a login. The integration expects an email, and refuses anything else. That causes an issue (in France) where the expected login is the verisure ID (not an email).
The issue has been escalated to the devs.
For more info: Link to issue
Hello
I also live in France
