Alarmo Exit Device
Hi all, I’m fairly new to HA and I have an issue with the alarmo integration. Everything seems to work fine except when I enter my code to arm the alarm, as soon as I open the entrance door (Which has a door binary sensor) Alarmo fails to arm and returns to the disarmed state. Is there a way to define something like an “exit device” that won’t trigger while arming thus not making Alarmo to fail? Or is there something else I am missing?
You have to set it up in Alarmo Panel → General → Modes → Select the mode you want to use the exit delay → Exit delay → set the amount of seconds you want
Then, in Sensors, you have to select the sensor you want to use the exit delay, in your case the entrance door sensor and enable “use exit delay”
Thank you so much!! Exactly what I was looking for!!!
