Hello I am using Alarmo running in a Pi4 and a Frient zigbee keypad, most things are working as intended with the exception of the entry timer.
If I set a 30 second entry timer before the alarm is triggered to allow sufficient time to disable the alarm, Alarmo goes into the state “pending”, whilst in this state I can disable Alarmo using the dashboard, but NOT using the Zigbee keypad.
If I set the entry timer to 0 (forcing the alarm to trigger immediately) I can disable using the zigbee keypad and the dashboard. Has anyone ran into this, i’ve got over it by delaying the siren activating for 30 seconds even though the alarm is in the triggered state immediately by using a helper and some automation.
Has anyone ran into this before ?
