I built an ESPHome keypad for Alarmo, using a nodeMCU and a TM1638 display, both from Amazon at a cost of about $10. Here is a pic:
Buttons 1 and 2 arm the system; button 3 calls for a PIN to be entered to disarm. The code uses the api to communicate with Alarmo, and could be modified to use other modes. I don’t use arm/disarm codes on my system, so the PIN (here 1234) is used only on the keypad. It could be sent to Alarmo in the data template if you use codes. Here is the code:
esphome:
platform: ESP8266
board: nodemcuv2
name_add_mac_suffix: false
on_boot:
then:
- lambda: id(pin_entry).publish_state(false);
- lambda: id(pin).publish_state("");
logger:
api:
ota:
improv_serial:
wifi:
ssid: !secret wifi_ssid
captive_portal:
web_server:
display:
platform: tm1638
stb_pin: D7
clk_pin: D5
dio_pin: D2
intensity: 4
update_interval: 100ms
lambda: |-
it.print (" ");
it.print (id(print_status).state.c_str());
text_sensor:
- platform: homeassistant
entity_id: "alarm_control_panel.alarmo"
on_value:
- if:
condition:
- lambda: "return id(pin).state.length() > 7;"
then:
- if:
condition: # correct PIN is entered
- lambda: |-
return id(pin).state.substr(4,4) == "1234";
then:
- homeassistant.service:
service: alarm_control_panel.alarm_disarm
data_template:
entity_id: alarm_control_panel.alarmo
- lambda: |-
else:
- lambda: |-
id(pin).publish_state("PIN?");
lambda: |-
if (id(pin_entry).state == true) {
return id(print_status).state = id(pin).state;
else if (id(alarm_status).state == "disarmed") {
return id(print_status).state = "DISARMED";
else if (id(alarm_status).state == "armed_home") {
return id(print_status).state = "ARM HOME";
else if (id(alarm_status).state == "armed_away") {
return id(print_status).state = "ARM AWAY";
else if (id(alarm_status).state == "arming") {
return id(print_status).state = "ARMING";
else if (id(alarm_status).state == "pending") {
return id(print_status).state = "PENDING";
else if (id(alarm_status).state == "triggered") {
return id(print_status).state = "TRIGGER";
else return id(print_status).state = "";
binary_sensor:
- platform: tm1638
# button will arm home or add 1 to pin
name: "TM1638 Button 1"
key: 0
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
- lambda: "return id(pin_entry).state == true;"
then:
- switch.turn_on: TM1638Led1
- lambda: |-
id(pin).publish_state(id(pin).state + "1");
else:
service: alarm_control_panel.alarm_arm_home
data_template:
on_release:
then:
- switch.turn_off: TM1638Led1
- platform: tm1638
#button will arm away or add 2 to pin
name: "TM1638 Button 2"
key: 1
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
then:
- switch.turn_on: TM1638Led2
- lambda: |-
id(pin).publish_state(id(pin).state + "2");
else:
service: alarm_control_panel.alarm_arm_away
data_template:
on_release:
then:
- switch.turn_off: TM1638Led2
- platform: tm1638
# button will change to pin entry or add 3 to pin
name: "TM1638 Button 3"
key: 2
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
then:
- switch.turn_on: TM1638Led3
- lambda: |-
id(pin).publish_state(id(pin).state + "3");
else:
- if:
condition:
- lambda: |-
return id(alarm_status).state == "disarmed";
then:
else:
- lambda: |-
id(pin_entry).publish_state(true);
on_release:
then:
- switch.turn_off: TM1638Led3
- platform: tm1638
name: "TM1638 Button 4"
key: 3
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
then:
- switch.turn_on: TM1638Led4
- lambda: |-
id(pin).publish_state(id(pin).state + "4");
else:
on_release:
then:
- switch.turn_off: TM1638Led4
- platform: tm1638
name: "TM1638 Button 5"
key: 4
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
then:
- switch.turn_on: TM1638Led5
- lambda: |-
id(pin).publish_state(id(pin).state + "5");
else:
on_release:
then:
- switch.turn_off: TM1638Led5
- platform: tm1638
name: "TM1638 Button 6"
key: 5
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
then:
- switch.turn_on: TM1638Led6
- lambda: |-
id(pin).publish_state(id(pin).state + "6");
else:
on_release:
then:
- switch.turn_off: TM1638Led6
- platform: tm1638
name: "TM1638 Button 7"
key: 6
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
then:
- switch.turn_on: TM1638Led7
- lambda: |-
id(pin).publish_state(id(pin).state + "7");
else:
on_release:
then:
- switch.turn_off: TM1638Led7
- platform: tm1638
name: "TM1638 Button 8"
key: 7
filters:
- delayed_on: 10ms
on_press:
- if:
condition:
then:
- switch.turn_on: TM1638Led8
- lambda: |-
id(pin).publish_state(id(pin).state + "8");
else:
on_release:
then:
- switch.turn_off: TM1638Led8
switch:
- platform: tm1638
led: 0
- platform: tm1638
led: 1
- platform: tm1638
led: 2
- platform: tm1638
led: 3
- platform: tm1638
led: 4
- platform: tm1638
led: 5
- platform: tm1638
led: 6
- platform: tm1638
led: 7
