Alarmo State Manager (Custom Actions)
A clean companion blueprint for Alarmo that does not replace Alarmo’s core security logic, but runs alongside it to trigger custom user-defined actions (lights, TTS, chimes, notifications, or switches) whenever Alarmo changes state (Arming, Disarmed, Armed in any mode, or Triggered).
Prerequisites:
- Alarmo Integration: You must have the Alarmo custom integration installed and configured in Home Assistant (
alarm_control_panel.alarmoor similar panel entity).
Features
Companion Architecture: Acts as an event responder alongside Alarmo without interfering with core alarm logic, sensor bypasses, exit delays, or PIN code verification.
Universal Armed Support: The single
Armedtrigger covers all Alarmo armed states (armed_away,armed_home,armed_night,armed_vacation, andarmed_custom_bypass). -
100% Optional Action Slots: Every action section is optional. Leave unused state blocks empty without causing errors or breaking automations.
Full Automation Engine Power: Supports multi-step action sequences, delays, parallel execution, loops (
repeat), conditions (if/then), text-to-speech (TTS), and local audio media playback. -
Operation Summary:
Event Action Taken Alarmo State Changes to ArmingRuns user-defined actions for the exit countdown (e.g., audio announcements, exit chimes, warning light flashes). Alarmo State Changes to DisarmedRuns user-defined actions for disarming (e.g., turning off sirens, turning on camera privacy switches, lighting welcome scenes). Alarmo State Changes to ArmedRuns user-defined actions when fully armed in any mode (e.g., locking door locks, turning off switches, setting security scenes). Alarmo State Changes to TriggeredRuns user-defined actions during an intrusion/breach (e.g., flashing alert lights, playing warning audio messages, sending notifications).
Blueprint Inputs
| Input | Description | Required? | Default |
| Alarmo Control Panel | The Alarmo entity that triggers this automation (alarm_control_panel.*). |
Yes | N/A |
| Actions when Arming | Custom sequence of actions to run when the alarm enters the exit countdown delay. | No | [] |
| Actions when Disarmed | Custom sequence of actions to run when the system is disarmed. | No | [] |
| Actions when Armed | Custom sequence of actions to run when armed in any mode (Away, Home, Night, Vacation, Custom). | No | [] |
| Actions when Triggered | Custom sequence of actions to run when the alarm is fully triggered. | No | [] |
Important Notes & Pro-Tips
- Companion Design Principle: This blueprint does not handle or store security PIN codes, nor does it override Alarmo’s built-in settings. It listens strictly to state change events published by your Alarmo panel.
- Audio & Visual Alerts: This blueprint is ideal for building custom exit countdown warnings (e.g., TTS announcements over smart speakers), ambient status cues, or emergency light-flashing sequences.
- Advanced Automation Logic inside Action Blocks: Because each state input uses Home Assistant’s native action selector, you are not limited to single device commands. You can build advanced internal logic using building block actions—such as adding
Delaytimers, running steps inParallel, creatingRepeatloops for flashing lights, or adding conditional checks (If-Then/Choose) to alter actions based on time of day, presence, or solar angles. - Error Handling & Offline Devices: By default, Home Assistant halts execution of an action sequence if a single step fails (such as an offline speaker or unresponsive light bulb). To ensure remaining steps continue running during device outages, enable “Continue on Error” on individual action steps within the Home Assistant automation UI editor.
- Safe Empty Execution: If you leave any of the four action slots blank when instantiating an automation, Home Assistant gracefully skips that state event without logging errors.
Installation
Method 1: Click to Import (Easiest)
Click the badge below to import this blueprint directly into your Home Assistant instance:
Method 2: Manual Installation
- Download or clone the raw YAML file from this repository:
alarmo_state_manager.yaml - In your Home Assistant configuration directory, navigate to your blueprints folder (e.g.,
config/blueprints/automation/ufans123/). - Paste the code into a file named
alarmo_state_manager.yaml. - Reload your automations or restart Home Assistant.
Method 3: Manual Installation using the Blueprints Dashboard (Easier)
- Copy the following URL:
https://github.com/ufans123/home-assistant-blueprints/blob/main/alarmo_state_manager.yaml
- Navigate to your Home Assistant Blueprints Dashboard UI (Settings > Automations & Scenes > Blueprints).
- In the bottom right corner, click on the ‘Import blueprint’ button.
- Paste in the URL and follow the prompts.
Changelog
| Version | Date | Summary of Changes |
| v1.0 | 2026-11-02 | Initial release |
