There are 3 light bulbs from Aldi (2 different types) installed. When trying to open the box with details (clicking the light device) a box pops up but not completely. The scroll bar does not pop up and the information is only partially displayed. Anyt idea how to fix this behaviour? Thank you.
You will need to give us more info, including what zigbee implementation you use.
Also a screenshot of what you are describing might help.
Ahhh I see.
Firstly, clear your browser cache (ctrl-f5) then reduce your browser enlargment/magnification (ctrl-0) or ctrl-minus.
My setup: Home Assistant latest version as a VM on a Synology 918+ (core-2021.5.5) and an USB-stick (2531)
Zigbee devices are connected via zigbee2mqtt to mosquitto mqtt both docker containers latest version.
No change at all. I tried a different browser and on my iPhone the same problem.
Is this only on lights, or other entities too?
There are 3 temperature/humidity sensors and one plug which are working correctly. 3 Aldi bulbs show this problem.
you may need to submit an issue to the frontend github:
Is this a frontend or a zigbee2mqtt problem? Thank you.
I would say that it’s likely a frontend issue.
the reason I say that is the integration is providing the info but just the display is messed up.
But of course I can’t be sure.
