Facing a somewhat exotic automation case. Would like to automate alerts if/when this odd scenario happens.
The thermostat (a Nest ‘e’) has been logged as calling for heat, then about 30 seconds later (and only sometimes) dropping the call and immediately reinitiating it, then holding the call on for the usual heating duration. (This has the effect of triggering an alert in the furnace’s internal module, since a heat-off-heat in rapid succession isn’t normal.)
I have an ESPHome device at the furnace which monitors the heat/fan/cool lines (using 24VAC relays driven by the thermostat, in parallel to the furnace), reporting the states of each to HA - as binary_sensors - at all times.
Yes, this problem is probably due to a defect in the thermostat firmware, but I’d like HA to help me catch it in the act
So, the goal is to compose a simple automation that triggers: If heat is called-for, but has been off for less than 1 minute, alert.
Is there a simple way to create such an automation/trigger?
