Alert integration and mqtt problem
I am trying to setup an alert integration and a custom mqtt notify service.
I have the alert working and it’s triggering as it should.
Also I have the mqtt notify working and tested it in an automation.
Problem is when trying to combine to use this notify in my alerts.
this is my mqtt notify integration
- unique_id: panel_say_notification
  name: "Panel Say Notification"
  command_topic: "alarmpanel/command"
  command_template: >
      { "speak": "{{ value }}" }
  qos: 0
  retain: false
This is my alert I am testing with.
room1_door_open:
  name: Room 1 Door Open
  entity_id: binary_sensor.room1_door_sensor_door_state
  state: "on"
  repeat:
    - 1
    - 45
    - 60
  can_acknowledge: true
  skip_first: false
  title:  Room 1 door notification
  message: >-
        Room 1 door has been open for {{((((as_timestamp(now())) -
        (as_timestamp(states.binary_sensor.room1_door_sensor_door_state.last_changed)))
        / 60 )) | int }} minutes
  notifiers:
    - persistent_notification
    - panel_say_notification
the persistant_notification works but get an error about panel_say_notification
in the log “homeassistant.components.alert] Failed to call notify.panel_say_notification, retrying at next notification interval”
turning on debug does not log anymore than this.
You might be better off just replacing the alert with an automation. Alert component is generally regarded as end-of-life and won’t really receive any further development. I’m not sure if it supports the new notify entities.
I have an automation today but want it to keep on notifying me until I close the door or dismiss the notification. Like when having this on a washing machine - I don’t have any sensors detecting that I actually have emptied the machine - so pressing dismiss for stop the reminders.
Also, if this is getting phased out - what is replacing it?
Did you ever find a solution for this issue? I’m experiencing the same problem.
