Hi all
i just started playing around with the “Alert” integration.
For testing I have setup the following in configuration.yaml:
alert:
hausture:
name: Haustüre ist noch offen
entity_id: binary_sensor.hmip_swdm_2_hausture
state: "on" # Optional, 'on' is the default value
# message: "Die Haustüre ist noch offen. Letzte Änderung: {{states.binary_sensor.hmip_swdm_2_hausture.last_changed | timestamp_local}}"
# done_message: "Die Haustüre wurde geschlossen um: {{states.binary_sensor.hmip_swdm_2_hausture.last_changed | timestamp_local}}"
repeat:
- 1
- 10
- 60
can_acknowledge: true # Optional, default is true
skip_first: true # Optional, false is the default
notifiers:
- Andre
- mobile_app_minime
tag: hausture
inline_keyboard:
- 'Acknowledge:/hausture_acknowledge'
I have two issues:
When I uncomment the “message” and “done_message” lines, I get no notification at all. I’m assuming I have the string syntax wrong but I’m fairly new to HA so any help is highly appreciated.
Secondly: I don’t understand how the “acknowledgement” in the comanion app works. When I click on the alert, it just opens the app. Do I understand correctly that I then ned to navigate to the state on my own?
