I have been using the config/www folder for storing quite a few little chime/ding-dong etc MP3 sounds for running before a TTS notification to a Google Nest Mini, is the still the best way of doing it?
I noticed I can get the same result by using the newer Media integration > Local Media (via an automation of course), so was just wondering what the best practice would be?
Can this support subfolders?
Thanks - have done that now.
Needed to Google how, but then Iām just stumbling my way through all this - for anyone following later; to see the root directory in the File Editor (and therefore get to the Media folder in order to subsequently add the subfolder) you need to change the config options of the File Editor add-on - āEnforce Baspathā > set to OFF.
Didnāt require anything in the configuration.yaml for me, but Iāve got the core installed on a NUC, FWIW.
TBH I donāt see why something like adding subfolders and better organisation tools arenāt available from within the GUI in the Media integrationā¦
Soooo - in summary - you would recommend the Media integration for simple sound effects in automations, rather than the WWW folder?..
