Juergen
(Juergen)
November 26, 2017, 4:17pm
1
Hey there,
I run a hass --script check_config
and do get the error:
2017-11-26 17:13:41 ERROR (MainThread) [homeassistant.config] Invalid config for [alert]: expected a dictionary for dictionary value @ data['alert']. Got [OrderedDict([('Schlafzimmer_Fenster_offen', OrderedDict([('name', 'Offenes Fenster im Schlafzimmer Alert'), ('entity_id', 'binary_sensor.schlafzimmer_cold_outside'), ('state', 'on'), ('repeat', [30, 5]), ('can_acknowledge', True), ('skip_first', 'true'), ('notifiers', ['iOS_iphone'])]))]), OrderedDict([('Bad_Fenster_offen', OrderedDict([('name', 'Offenes Fenster im Bad Alert'), ('entity_id', 'binary_sensor.bad_cold_outside'), ('state', 'on'), ('repeat', [30, 5]), ('can_acknowledge', True), (.... (See /home/homeassistant/.homeassistant/configuration.yaml, line 316). Please check the docs at https://home-assistant.io/components/alert/
2017-11-26 17:13:41 ERROR (MainThread) [homeassistant.setup] Setup failed for alert: Invalid config.
My config in configraiton.yaml looks like:
alert: !include alerts.yaml
and the alerts.yaml contains:
#alert:
- Schlafzimmer_Fenster_offen:
name: Offenes Fenster im Schlafzimmer Alert
entity_id: binary_sensor.schlafzimmer_cold_outside
state: 'on'
repeat:
- 30
- 5
can_acknowledge: True
skip_first: 'true'
notifiers:
- iOS_iphone
- Bad_Fenster_offen:
name: Offenes Fenster im Bad Alert
entity_id: binary_sensor.bad_cold_outside
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
- Buero_Fenster_offen:
name: Offenes Fenster im Buero Alert
entity_id: binary_sensor.buero_cold_outside
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
You need to remove the alert:
line from the include file, and align everything else back to the left, keeping the formatting the same, but removing the hyphens…
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
Bad_Fenster_offen:
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
(please note I’ve edited that on my phone so there may be a stray space or two)
Juergen
(Juergen)
November 26, 2017, 5:36pm
3
The result of alerts.yaml
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
Bad_Fenster_offen:
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
hass --script check_config is telling me:
2017-11-26 18:33:49 ERROR (MainThread) [homeassistant.config] Invalid config for [alert]: [Schlafzimmer_Fenster_offen] is an invalid option for [alert]. Check: alert->alert->Schlafzimmer_Fenster_offen. (See /home/homeassistant/.homeassistant/configuration.yaml, line 316). Please check the docs at https://home-assistant.io/components/alert/
2017-11-26 18:33:49 ERROR (MainThread) [homeassistant.setup] Setup failed for alert: Invalid config.
You might have to take the capital letters out of the first line of each alert (the lines that are all the way across to the left) , some components don’t like it for some reason.
Juergen
(Juergen)
November 26, 2017, 7:07pm
5
Thanks.
now working. Important was NO capital Letters and no blanks in the first line.
How would I change the syntax of each Alert when I change from
where I have one file inlcuding all alerts to a more individual solution to have one yaml for every alert. So a change to
alert: !include_dir_merge_named Alerts
with files like:
schlafzimmer_fenster_offen.yaml
bad_fenster_offen.yaml
buero_fenster_offen.yaml
Juergen
(Juergen)
November 26, 2017, 7:16pm
6
created a directory Alerts and created three individual files
schlafzimmer_fenster_offen:
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
bad_fenster_offen:
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
buero_fenster_offen:
state: 'on'
repeat:
- 30
- 5
skip_first: 'true'
notifiers:
- iOS_iphone
does run through without issues. Let’s see if it is working after my new start of HA
