I keep getting the following error in my logs;
Invalid config for ‘alert’ at alerts.yaml, line 1: required key ‘entity_id’ not provided, please check the docs at Alert - Home Assistant Invalid config for ‘alert’ at alerts.yaml, line 1: required key ‘name’ not provided, please check the docs at Alert - Home Assistant Invalid config for ‘alert’ at alerts.yaml, line 1: required key ‘repeat’ not provided, please check the docs at Alert - Home Assistant Invalid config for ‘alert’ at alerts.yaml, line 2: ‘freezer_alert’ is an invalid option for ‘alert’, check: alert->alert->freezer_alert, please check the docs at Alert - Home Assistant
The alerts.yaml is below;
alert: # Added main alert section
freezer:
name: “freezeralerts” # Fixed missing name key and indentation
entity_id: binary_sensor.freezer_alert # Indented
state: “on” # Fixed indentation (one level less)
message: “Freezer temp is too high” # Indented
notify: # Fixed indentation (one level less)
- mobile_app_pixel_7_pro_lindsay # Indented with one more level
Sorry about that, please find below (I hope a correctly formated) example of my alert.yalm, this is referenced in my configuartion.yaml file. The error I am seeing in my logs refers to line one of this file (Invalid config for ‘alert’ at alerts.yaml, line 1: required key ‘entity_id’ not provided). The purpose of this is to use alerts to notify me when our freezer door is being left open and the temperture gets up.
alert:
freezer:
state: "on"
message: "Freezer temp is too high"
notify:
Hi folks,
This is now resolved. Going through it line by line, restarting the system every time but it’s resolved and I’ve a working example that can form a template for the rest/if any alerts I need.
