I am looking to create alerts that send me messages via MQTT when door sensors are opened/closed or are left open for a certain period of time. The idea is that if the door is left open for longer than 30 minutes, it would repeat the alert.
I would also like to create a humidity alert for all humidity sensors that would send repeated messages every hour when the humidity is above a threshold.
I’m confused as to whether I should use “Alerts” or “Automations” to achieve this. Also how can I select all humidity sensors by category/class instead of individually specifying each sensor?
I would appreciate any advice in this regard and thank you in advance
