AlertTicker Card for Home Assistant
A custom Lovelace card to display alerts and notifications based on entity states. Supports 40 visual themes (including 4 dedicated timer themes), 12 transition animations, card interactions, entity filter, alert history, snooze, secondary entity values, timer countdown, full Jinja2 template support, vertical layout, HA global theme adaptation, global overlay/toast notifications visible from any dashboard view , and a complete visual editor — all without writing a single line of YAML.
Incredible card!
In my side it miss only one thing :smiley:
The last update of the event
Very good work and shared !
this is great!
well done, very handy card
really fine addon for my front panel to summarize the most important topics seen in the house.
Watched ‘Smart Home Junkie’s’ video just now about this card (https://www.youtube.com/watch?v=pXRYqlzeUb8) and I think it’s a game changer!! I’m going to give it a go later today but from what I saw it seems to be very well done and complete, thank you! :+1:t2::blush:
does anyone know how to do an if condition within the alerts depending on certain entities - for instance if the front door is open - display Front Door Open/Unlocked vs front door closed - display Front Door Closed/Unlocked
I would like to know is there a simple way that I am not seeing to enable this card across multiple tabs of a dashboard without creating multiple instances of the card?
IE: to be permanently displayed no matter which tab is selected
Earlier version was behaving correct but since upgraded to the latest available version, seems conditions are not getting evaluated. Below code sgould be Alerting only if any of the conditions are met, buy card displays alert all time though the state in alert says clear. Below is the code. Anything wrong I am attempting because the same code was working in previous version but not correctly displaying alerts now.
cycle_interval: 5
show_when_clear: false
clear_message: ""
clear_theme: success
alerts:
  - operator: "="
    state: "on"
    message: Motion detected
    priority: 2
    theme: motion
    icon: 👁️
    entity_filter: binary_sensor.*radar*
    entity_filter_exclude:
      - sensor.radar_bedroom_ip
      - sensor.radar_guestbedroom_ip
      - sensor.radar_kitchen_ip
      - binary_sensor.motion_radars
    show_filter_state: true
    show_badge: false
    conditions:
      - entity: zone.home
        operator: "="
        state: "0"
      - entity: schedule.bedtime_schedule
        operator: "="
        state: "on"
    conditions_logic: or
type: custom:alert-ticker-card
cycle_animation: fold
ha_theme: true
Im glad to hear it worked before, i thought i was not doing something right or misunderstood the card function. I just installed this last night and noticed the same thing. It looks like the code is treating the main entity state and conditions as the same. So if you have an ‘or’ then if any of the conditions or entity state are true it will trigger the card and if you set up ‘and’ for the conditions then all conditions and state must be true to trigger the event ( which would make the ‘and’ condition setting to seem to be executed correctly).
So basically it seems like the card isn’t distinguishing between the trigger and condition. I will open an issue on github.
Otherwise this is a great card.
Did we get any luck on this or its the same for now?
I like this card and it works great, the only problem I have is that the font is too small and it’s hard to read on a HD display.
I tried increasing the font with: overlay_scale: 2 and also tried using card-mod:
card_mod:
  style: |
    ha-card {
      --card-primary-font-size: 30px !important;
      --card-secondary-font-size: 30px !important;
Neither option worked.
Has anybody been able to change font size?
