Alexa 2 Way switching, can it be done with Emulated Hue?
Hi I want to set up an 433Mhz RF Relay as a 2 way switch, i.e. works in conjunction with another switch.
Is there a command that I can use with Alexa with Emulated Hue that is a toggle, i.e. I don’t want to Say Lights “On” Or “Off” I just want to say Alexa Kitchen Light, and with 2 way wiring if its “On” it will go “Off” and if its “Off” it will come “On”
I hope I have made myself clear, not sure what they call 2 ways switching outside of the UK.
Regards Dave
Not sure if this works, but have you tried within the Alexa app to create a group and add the switch to it? I think whenever you say the group name it activates. I’ll have to test when I’m at home tonight but it may be worth a try.
Many thanks for the reply
That sounds like a plan, have not played with groups yet, love to see your code if you can get it working.
I will also have a look
Re Dave
Actually I meant inside the Alexa app, assign your device to a group.
Been a while, I now have some Sonoff power switches, there is a TOGGLE command the will work with the Sonoff but is there anyway Alexa can trigger it. I have tried the group thing but you have to say Group Name and then On or Off.
I need Alexa to reconise a Toggle command
Any thoughts?
Re Dave
