in order to have the best “connection” between HA and my Alexas I just successfully installed/activated Nabu Casa.
I was hoping to be able now to give Alexa a voice query-command, that would be passed to HA (e.g. to query the current power of the photovoltaic system) and HA would return the result to the Alexa, that received the command.
I have no clue, how to do that.
Any advice or pointer to according documentation would be appreciated.
You would need to expose that entity to Alexa either in the Voice Assistants section (Settings>Voice Assistants>Alexa) or in the settings for the entity itself. You can then ask something like “Alexa, what is the value of “[entity name”]”.
However, with that said, entities like power and energy aren’t supported by Alexa. So, I think the only way you could do something like that would be to use the Alexa Media Player integration and use a combination of an Alexa routine along with a script in HA.
Is there any chance to identify the Echo device that received the command and then dynamically address the media player entity for that device to send the resply?
Currently I use a button to start an automation that collects the PV values and sends that via media player to an Echo, that is hard-wired in the automation.
Thank you c-i-p.
I almost got it working now.
My voice command triggers an Alexa routine, that sets a helper-switch in HA for 5 sec. That is detected by the automation, that sends information to notify.alexa_media_last_called media player service.
It works for the echo next to my computer. But when I speak to another echo device, the response is always sent to to echo next to my computer, not to the echo I spoke to.
Show your script or automation or flow. We don’t know what you’re missing if we can’t see it.
Process is call Alexa last called and use it’s output to prime the entity ID for your notification.
Be advised lately reliability seems to have dropped on last called due (i hear rumors on throttling Alexa side? But not sure.) Mines fine for me but I’d say it’s got about a 90% accuracy rate with my 6 echos…
- id: "1714830448301"
alias: Sonnentest
description: Sonnentest
- platform: state
entity_id:
- input_boolean.pv_status
to: "on"
condition: []
- service: notify.alexa_media_last_called
message: "Die PV-Leistung beträgt {{ states('sensor.sn_3002451053_pv_power') }} Watt."
mode: single
How would that service call to alexa_media.update_last_called look like?
Update:
According to this page: " As of >= 3.6.0, a notify target will be created automatically notify.alexa_media_last_called."
… it should work in theory (but as Nathan pointed out, reliability is obviously poor).
So next thing to try is the service call, that Bill mentioned.
