@juan11perez Thanks for the suggestion. I actually deleted everything from my Amazon account and re-activated them all and it still didn’t resolve it. Oh well…at least Node-Red works for me so I’ll just lay emulated_hue to rest
sorry it didnt help.
thanks for the Family Map
@juan11perez You’re welcome!
Just thought of something else unusual that happened before. have you got the javascript_version (https://home-assistant.io/components/frontend/_in latest?
When first released in 0.59 it was blocking some google assistant instances and the pychromecast. I dont know enough to say why, but my chromecast stopped working. When I commented out javascript_version: latest, it worked again.
Cheers Jeremy, do need to get my head around input booleans, have managed without to avoid them so far but know they’ll simplify/extend some of my automations.
As your using a Harmony hub, have you tried emulated_roku, easy to set up and you can assign any key to trigger things in HA which also means they’re easier to integrate into activities.
That’s just the original red skill renamed after they finally deigned to share the blue skill with the rest of us but does have the added bonus of getting around some conflicts when smart home skill names get a bit too close for Alexa to get right every time.
@Bobby_Nobble Yeah like I said, I mostly use input_booleans for configuring options and then use them as conditions in my scripts. I find they are extremely useful because I don’t always want the automations to run or parts of my text to speech in scripts to say so I find they are incredibly useful. I’m sure you’ll find tons of uses for them. Here’s some examples:
Emulated_roku? Never heard of it before. Cool! I have to check this out! Thanks!
Chars.
Here it is…
Don’t know why it got overlooked when @mindigmarton launched it six months ago, I missed it completely, but it’s great that he’s still committed now people are waking up to it.
Awesome! Thanks @Bobby_Nobble
funny enough but my situation is about the same.
used emulated hue for a long time, but it stopped working about two weeks ago.
I’ve deleted all devices and ran discovery but this time nothing was found. tried resetting unlinking etc but no luck.
Ended up with HA Cloud which worked as soon as I moved alexa to the US store. But i’m not going to pay $5/
Tonight I decided to give node-red a chance an it is amazing!! I love it.
Local alexa worked instantly no idea why it is different from emu_hue.
if you want to try it:
curl -sL https://deb.nodesource.com/setup_9.x | sudo -E bash -
sudo apt-get install -y nodejs npmsudo npm install -g --unsafe-perm node-red
sudo npm install node-red-contrib-alexa-local
jkw
Just one additional question: I’ve implemented all my rules into node red now and let it run for a day. It turned out to consume quite a bit of cpu power (load changed to 0.5 from 0.08-ish) have you seen similar behavior? This is my setup at the moment
Jkw
I only have this active and I also saw an increase RAM and cpu. however I still prefer Node-Red from the mere hours I tinkered with it.
[{"id":"c55b6686.6e93e8","type":"api-call-service","z":"ed017238.5b8b8","name":"Turn off lights","server":"54dd7c56.249fa4","service_domain":"light","service":"turn_off","data":"{ \"entity_id\": \"light.ledstrip\" }","x":1640,"y":100,"wires":[]},{"id":"6cce8584.f1ff94","type":"api-call-service","z":"ed017238.5b8b8","name":"Turn on Lights","server":"54dd7c56.249fa4","service_domain":"light","service":"turn_on","data":"{\"entity_id\": \"light.ledstrip\", \"brightness\": 1}","x":1640,"y":20,"wires":[]},{"id":"473c32e9.8db284","type":"api-current-state","z":"ed017238.5b8b8","name":"Off Already?","server":"54dd7c56.249fa4","halt_if":"off","entity_id":"light.ledstrip","x":1450,"y":100,"wires":[["c55b6686.6e93e8"]]},{"id":"d1d9c656.37bdd8","type":"server-state-changed","z":"ed017238.5b8b8","name":"Livingroom Motion","server":"54dd7c56.249fa4","entityidfilter":"binary_sensor.office_motion","haltifstate":"","x":150,"y":20,"wires":[["18cbacbb.a70c53","21376354.e5db9c"]],"outputLabels":["dark"]},{"id":"47c04288.25a8ac","type":"api-current-state","z":"ed017238.5b8b8","name":"Already On?","server":"54dd7c56.249fa4","halt_if":"on","entity_id":"light.ledstrip","x":1450,"y":20,"wires":[["6cce8584.f1ff94"]]},{"id":"ba4cbf35.7af01","type":"stoptimer","z":"ed017238.5b8b8","duration":"10","units":"Second","payloadtype":"num","payloadval":"0","name":"10sec test","x":1010,"y":100,"wires":[["b927130c.5e375"],[]]},{"id":"f4f97eab.03359","type":"inject","z":"ed017238.5b8b8","name":"TEST Livingroom 'motion' ","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"x":130,"y":180,"wires":[["21376354.e5db9c"]]},{"id":"d3f7f7da.2fa938","type":"time-range-switch","z":"ed017238.5b8b8","name":"Dusk-Dawn range","lat":"52.007288","lon":"5.722599","startTime":"dusk","endTime":"dawn","startOffset":"-30","endOffset":"30","x":570,"y":100,"wires":[["de3c6260.4bf7f"],[]]},{"id":"b927130c.5e375","type":"api-current-state","z":"ed017238.5b8b8","name":"Guest Mode ON/OFF","server":"54dd7c56.249fa4","halt_if":"on","entity_id":"input_boolean.guest_mode","x":1240,"y":100,"wires":[["473c32e9.8db284"]]},{"id":"c656cae0.f56cc8","type":"server-state-changed","z":"ed017238.5b8b8","name":"Guest Mode refresh","server":"54dd7c56.249fa4","entityidfilter":"input_boolean.guest_mode","haltifstate":"","x":150,"y":100,"wires":[["21376354.e5db9c"]],"outputLabels":["Dark"]},{"id":"aa9cd92a.9e1538","type":"api-current-state","z":"ed017238.5b8b8","name":"Home?","server":"54dd7c56.249fa4","halt_if":"away","entity_id":"group.athome","x":1200,"y":20,"wires":[["47c04288.25a8ac"]]},{"id":"21376354.e5db9c","type":"switch","z":"ed017238.5b8b8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off, 1","vt":"str"}],"checkall":"true","outputs":1,"x":370,"y":100,"wires":[["d3f7f7da.2fa938"]]},{"id":"18cbacbb.a70c53","type":"api-current-state","z":"ed017238.5b8b8","name":"Dark by weather (test)","server":"54dd7c56.249fa4","halt_if":"0","entity_id":"sensor.dark_sky_cloud_coverage","x":580,"y":20,"wires":[["84349707.e62bf8"]]},{"id":"84349707.e62bf8","type":"switch","z":"ed017238.5b8b8","name":"Minimum clouds %","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"100","vt":"num"}],"checkall":"true","outputs":1,"x":810,"y":20,"wires":[["ba4cbf35.7af01","aa9cd92a.9e1538"]]},{"id":"de3c6260.4bf7f","type":"switch","z":"ed017238.5b8b8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1, off","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"false","outputs":2,"x":770,"y":100,"wires":[["ba4cbf35.7af01","aa9cd92a.9e1538"],["ba4cbf35.7af01"]]},{"id":"54dd7c56.249fa4","type":"server","z":"","name":"Home Assistant (Hassio)","url":"http://192.168.178.42:8123","pass":"welcome"}]
FYI I have all the passwords still on default without encryption because its my test setup
Well, after exploring emulated_hue and tons of switch entity, the amount of components that exposed to Alexa is too big to start filter them one by one.
After week of searching I found node-red best framework to workaround the amount of entity exposed to Alexa.
