I would like to ask Alexa what the tempeture from a sensor is. In the furter more sensors.
But the intent part on alexa, i can get it how it works. Have try a lot.
On this forum in found this:
alexa:
intents:
TemperatureIntent: “The temperature is {{ sensor.temperature.state }} degrees”
I would like to ask something like this: Alexa, what is the room temperture?
The sensor is: sensor.toontemp
What is the correct intent config for developer.amazon.com?
Thanks for the help! If i have it working, i post here my whole sensor config, to help others.
Sample Utterances
TemperatureIntent What is the temperature
TemperatureIntent the temperature
TemperatureIntent what is the room
Home assistant config:
alexa:
intents:
TemperatureIntent:
speech:
type: plaintext
text: >
The temperature is {{ states.sensor.toon.state.split("\n")[0] }} degrees
As i test this skill on developer.amazon.com it works! he give me the right answer and sensor date.
But now, why home assistant give me not the good answer if i ask?
He give me the inbuild weather information if i ask, what is the temperture.
Also if i ask: Alexa, ask home assistant what is the temperature?
This is what I use as the intent for “Alexa, ask Home Assistant for the temperature of .”
speech:
type: plaintext
text: >
The {{ Room }} temperature is
{{ states("sensor." + Room.replace(" ", "_") + "_temperature") }}
degrees.
Or, for a more detailed sensor example that doesn’t have a variable input, here’s what I use for “Alexa, ask Home Assistant about the weather.”:
speech:
type: plaintext
text: >
{%- set temp = states('sensor.dark_sky_temperature') | round -%}
{%- set t_hi = states('sensor.dark_sky_daily_high_temperature') | round -%}
{%- set t_low = states('sensor.dark_sky_daily_low_temperature') | round -%}
{%- set feel = states('sensor.dark_sky_apparent_temperature') | round -%}
{%- set humid = states('sensor.dark_sky_humidity') | round -%}
{%- set now = states('sensor.dark_sky_summary') -%}
{%- set hourly = states('sensor.dark_sky_hourly_summary') -%}
{%- set daily = states('sensor.dark_sky_daily_summary') -%}
Right now, it is {{ temp }} degrees out
{%- if temp != feel -%}
but it feels like {{ feel }} degrees
{%- endif -%}.
The current humidity is {{ humid }}%.
Right now, conditions are {{ now }}.
For today, {{ hourly }}.
Today's high is {{ t_hi }} and the low is {{ t_low }}.
The forecast calls for {{ daily }}.
Hello I am new to HA and Alexa. Just wondering how to set up all the configurations, I already have Alexa setup with HA, I have multiple sensors DTH22 and DS18B20, and would like to ask about different room temperatures and humidity. Thank you
