It seems directed towards opening up your own ports to connect. I chose the home assistant cloud solution instead.
I was wondering how I can do the custom responses. I’ve created the alexa_confirm.yaml and added the content from the how to. In addition to this I’ve added the following lines to configuration.yaml
if nobody found a solution, here a kinda solution:
you can put the template directly there:
message: '{{ [ "master just arrive", "master is in the driveway", "master
is in the place!", "here come master", "master arrival imminent", "master
vient de rentray", "master vient darrivay", "make place peasant. the master
juste arrive", "I annouce the arrival of master", "make note of the impending
arrival of master", "do not worry. you are not alone anymore. master just
arrive", "unfortunately. master just arrive", "sory to botter you. but
master is here" ] | random }}'
this is for google tts, but it should work with alexa too
