As per headline, hopefully not too hard to implement
I use scripts to get Alexa to change my input select.
Are you able to run scripts with the Cloud component? I have only been able to turn scripts on and off, not actually run them. I can only run scripts from Alexa using my own custom skill, but that requires an invocation word. That’s what I’m trying to avoid.
I actually use haaska which I think is the same as cloud but free. It essentially creates a template switch that has the on and off command the execution of the script. I have a TV that has three positions (input select) and I say,
Alexa, turn on position two
I actually run Haaska too. My scripts show up in Alexa Smart Home as switches, so maybe I just need to work some more on the scripts. Thanks
Need this feature to support brightness ala automation to a group. Or support brightness for groups. Either one will allow me to dim/brighten groups via Alexa.
Is this avaliable now?
