after changing to newest version of the freeathome component and changing to HA OS 6.6 and Core core-2021.11.5 it’s not possible to control my covers via the Home Assistant Cloud ALEXA function anymore. In the past I was able to use commands like “Alex, Rollladen Buero 50%” and it works fine. Now Alexa asks back: “Which setting?” When I answer “Oeffnungsgrad” it works fine. On Alexa’s side I configured the shutter as an “switch” or as “EXTERIOR_BLIND”. In both ways, the problem stays the same.
What can I do to ask Alexa with commands like “open/close Rollladen Buero” or working with percentage information without the “Oefnnungsgrad”?
But when did they change it? Just one day ago everything works fine for me. So I guess thats anorher problem? You are right “Alex, turn on/turn off …” helps but I still looking for a percentage solution. Thanks for your help. Br Jens
Well, in a way I guess that is good. Means they should get it up and working shortly. AWS makes way too much money for Amazon, so they will fix it a.s.a.p.
