Hello and thank you for reading and even more for your suggestions.
I am proud of how far I’ve come without having to post a question. I created my first Alexa Wemo switch, using a ESP8266 and Kakopappa’s Aleza Wemo github https://github.com/kakopappa/arduino-esp8266-alexa-wemo-switch/blob/master/sinric.ino
I created first switch, “Fan Light”, once I uploaded the sketch Alexa discovered it on first try, and when I checked Home Assistant “overview” the switch was listed. This was the ESP8266 with the code same as above.
Once first switch was stable (fan light), i was able to turn on and off via Alexa and via Home Assistant dashboard
I then created a second switch, “LivingRoom”. To this ESP8266 I added a sensor touch button. When I upload the sketch the touch sensor works as expected, and Alexa also discovers it on the first try. I can turn light on and off with Alexa or by using the sensor touch. However Home Assistant doesn’t discover it at all.
I created a third switch, “LED test”, and same result, I can turn it on and off with Alexa (discovered at first try).
So at this point with Alexa I can control 3 different switches, one of them has a touch sensor attached that works as expected. However Home Assistant only sees one of them.
For the “LivingRoom” switch I did make a couple of changes to see if it would work but it didn’t. I changed a digit on the serial number, I changed a digit on the PSTR on this line sprintf_P(uuid, PSTR(“38323636-4558-4dda-9188-cda0e6%02x%02x%02x”),
I am a total noob, but I am guessing that all 3 switches are using the same ID that Home Assistant looks at, hence only shows one, but Alexa doesn’t look at that ID hence it doesn’t care that all 3 are the same.
Anyhow, I assume my guess is wrong and hoping one of your great minds might shade some light to what is going on
