I’m pretty sure the proactive events are working as in the Alexa app I look at one of my light devices that are controlled by Home Assistant - if I switch it ON/OFF from the home assistant front end I see the state change in the Alexa App - I assume that is proactive events working? I also see debug logging push the state to Alexa,
Did you have any luck with this? en-GB is in the list now.
I’ve tried to set mine up with the same {state: "on"} that I use for lights… but not sure if I should be reverting it to state off straight after or if its even being sent proactively.
Amazon wants to see a payload of cause and timestamp but even sending this doesn’t seem to trigger it. "payload" : { "cause": { "type": "PHYSICAL_INTERACTION" }, "timestamp": "2020-12-29T23:09:58.128Z" }
Reviving this as there isn’t much on the topic yet as it seems new. Hopefully we can figure this out together.
And the input boolean is configured in configuration.yaml like so (although I believe you can now do this via the UI):
input_boolean:
front_doorbell:
This might be slightly more complex than needed but this is because I use a 433Mhz doorbell using the rfxtrx integration so I just get an event when the door bell is pushed.
So I then have an automation that when the event arrives I set the input_boolean:
It seems that this has stopped working properly now - it works the first time after a Home Assistant restart but then not on subsequent doorbell events - any one else seeing similar?
