When I loaded that file into Audacity, I saw the sample rate was set to 48000Hz. According to amazon, it needs to be set to 22050Hz. Try changing the sample rate and re-uploading. That was the issue I kept having when trying audio files, as the bitrate was correct, but the sample rate was too high.
I make sure to convert my mp3’s at jovo and then are hosting them at backblaze even though my url should be publically accessible. That’s the only way I was able to get them all to work properly.
I was testing the same and I couldn’t figure out the issue with this.
For me, it turned out to be an issue with the test URL from Jovo that I was given.
Apparently Amazon now prevents playing MP3s from their domain. Uploading the MP3 to a different URL worked perfectly fine.
I have the same problem! I checked the files that are in the right format but nothing to do, I posted the mp3 file on HA, I also tried in other places but nothing; does anyone have any advice?
I have 4 echodots and I’m using an iobroker. I tried to let my echos say a text, but at the moment i only get the answer “having trouble accessing …” Neither “Speak” nor “Announcement” works.
I read the postings above but there is (in my opinion) a .wav / .mp3 file the problem. Now i have a problem with the TTS.
Could anyboy help me, or does anybody has an idea how to fix this issue?
