Alexa-home missing in Node-red add-on on Hass.io
Hello, it seems that alexa-home and alexa-home-conf packages have been removed from the Node-red add-on in the Hass.io installation. Does someone tell me how to install thees packages. npm command doesn’t work in SSHTerminal
Thanks in advance
have you tried the palette manager?
Yes, but these packages (alexa-home and alexa-home-conf) are not available anymore, they have been excluded in the latest versions of the add-on Node-red:
imagen
the screenshots show where you go to install the package containing those nodes, as you asked.
I’m not sure which of those shown is the right one (I don’t use Alexa), but node-red-contrib-alexa-home looks like a good candidate.
Hamburger Menu (top right) => Manage Palettes, select the Install tab and search for Alexa.
