Alexa Integration does not discover devices
Hoping someone can help with this.
Successfully integrated Alexa with local HA instance. All my devices imported without issue following the main guide on the HA site.
At some point I deleted all the home assistant devices from Alexa and disabled the skill. A week later I am trying to set this up again and this is where the fun begins.
Enabling the skill is always successful but never discovers any devices. I’ve gone as far as completely starting over with new lamdba functions and alexa skills. I have also tried setting things up via the Haaska guide. Each time the lambda test script passes successfully and I can enable the Alexa skill and authorize without issue.
My configuration.yaml file only has the below
api:
alexa:
smart_home:
Not sure what else to try at this point. Any help would be greatly appreciated.
Never found a solution to this. Ended up wiping home assistant and starting over.
