Alexa Integration - ESPHome Alarm Control Panel away mode not working
Hi Everyone,
i’m facing a strange issue where i’m not able to make Alexa Integration working as expected with my custom Alarm System based on ESPHome (Template alarm control panel).
Problem is that i’m not able to trigger ARM_AWAY state with any of the suggested phrases (i’m using IT-it locale).(ARM_HOME and DISARM are working well)
I’ve followed the integration guide, skill is in place, account is linked, device are recognized.
This is the relevant JSON section of the discovery triggered from the AWS lambda:
          "displayCategories": [
            "SECURITY_PANEL"
          "cookie": {},
          "endpointId": "alarm_control_panel#allarme_pannello_allarme",
          "friendlyName": "Antifurto",
          "description": "alarm_control_panel.allarme_pannello_allarme via Home Assistant",
          "manufacturerName": "Home Assistant",
          "additionalAttributes": {
            "manufacturer": "Home Assistant",
            "model": "alarm_control_panel",
            "softwareVersion": "2024.12.3",
            "customIdentifier": "-alarm_control_panel.allarme_pannello_allarme"
          "capabilities": [
              "type": "AlexaInterface",
              "interface": "Alexa.SecurityPanelController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "armState"
                "proactivelyReported": true,
                "retrievable": true
              "configuration": {
                "supportedArmStates": [
                    "value": "DISARMED"
                    "value": "ARMED_AWAY"
                    "value": "ARMED_STAY"
                "supportedAuthorizationTypes": [
                    "type": "FOUR_DIGIT_PIN"
              "interface": "Alexa.EndpointHealth",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "connectivity"
                "retrievable": true
              "interface": "Alexa",
              "version": "3"
My suspect is that the Italian utterance is not recognized as expected but i’m not sure…
do you have any clue on how to deeply troubleshoot or solve this annoying problem?
Thank you!!
Luca
Am i the only one? :frowning:
Update:
Switching to English(UK) make it works so definitely issue with Italian.
Does anyone knows how to troubleshoot or raise a defect?
Thanks ,
Luca
