I’m having trouble integrating my AWS with my Home Assistant that is in a VirtualBox on Linux. It is already properly exposed and I can access it from outside my network.
I don’t use DuckDNS. I do the process via Cloudfare and, at first, everything is ok. This is the payload I get when I try to test the connection between Lambda and HA:
Did you solve the problem. I stuck at the same point.
AWS Test results in the error:
“event”: {
“payload”: {
“type”: “INVALID_AUTHORIZATION_CREDENTIAL”,
“message”: “401: Unauthorized”
HA notifies me with the message:
Login attempt failed
Login attempt or request with invalid authentication from ec2-54-74-7-242.eu-west-1.compute.amazonaws.com (54.74.7.242). See the log for details.
The logbook-entry is:
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:82
Integration: HTTP (documentation, issues)
First occurred: 17:12:49 (1 occurrences)
Last logged: 17:12:49
Login attempt or request with invalid authentication from ec2-54-74-7-242.eu-west-1.compute.amazonaws.com (54.74.7.242). Requested URL: ‘/api/alexa/smart_home’. (python-urllib3/1.26.9)
