All,
I am using last_called_summary from the Alexa Media Player, but it’s obviously unreliable.
If I check the last_called_summary attribute when talking to Alexa it sometimes changes (seldomly) and and very often not.
In the App I have created some routines which tells me, that Alexa understood, but this phrase does only show up sometimes in the attribute.
I am using Nabu Casa.
You are right - that seems to work.
Thank you so much.
I will try to implement this right away
The only thing is, that there is no indication that one of the Echos has been called.
So I would need to poll / update my 5 Echos permanently, which seems to be an overkill.
Recognizing that your Echos may be a different model than mine–I have a bunch of gen 2 Echos. In Developer Tools>States, if I filter the Attributes column with ‘last_called’, they all show a value. After a reboot, before calling the alexa_media.update_last_called service, that value is ‘null’ but, after then calling update_last_called, they all become ‘false’ except one which is ‘true’. The same applies to my Alexa-capable Sonos speakers.
