I’m getting the below error multiple times in the logs any ideas?
2019-11-13 17:12:37 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 981, in create_connection
ssl_handshake_timeout=ssl_handshake_timeout)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 1009, in _create_connection_transport
await waiter
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 804, in _read_ready__data_received
data = self._sock.recv(self.max_size)
ConnectionResetError: [Errno 104] Connection reset by peer
File "/config/custom_components/alexa_media/media_player.py", line 278, in _handle_event
await _refresh_if_no_audiopush(already_refreshed)
File "/config/custom_components/alexa_media/media_player.py", line 194, in _refresh_if_no_audiopush
await self.async_update()
File "/config/custom_components/alexa_media/media_player.py", line 565, in async_update
no_throttle=True)
File "/config/custom_components/alexa_media/helpers.py", line 143, in wrapper
result = await func(*args, **kwargs)
File "/config/custom_components/alexa_media/media_player.py", line 362, in refresh
session = await self.alexa_api.get_state()
File "/usr/local/lib/python3.7/site-packages/alexapy/alexaapi.py", line 456, in get_state
'&screenWidth=2560')
File "/usr/local/lib/python3.7/site-packages/alexapy/alexaapi.py", line 104, in _get_request
return await self._request('get', uri, data)
File "/usr/local/lib/python3.7/site-packages/alexapy/alexaapi.py", line 73, in _request
ssl=self._login._ssl)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
timeout=real_timeout
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 1004, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
req=req, client_error=client_error)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 943, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host alexa.amazon.com:443 ssl:<ssl.SSLContext object at 0x7f71693a1980> [Connection reset by peer]
2019-11-13 17:12:55 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
await waiter
