Alexa Media Player - "Last Alexa" showing as "unavailable" all of a sudden
I’ve been using the Alexa Media Player integration, and the Last Alexa template sensor, for a long time.
All of a sudden Last Alexa is now showing as unavailable, and I’m not sure why. For reference the template sensor is configured in my configuration.yaml as:
template:
  - sensor:
    - name: Last Alexa
      state: |-
        {{ expand(integration_entities('alexa_media') | select('search', 'media_player'))
        | selectattr('attributes.last_called', 'eq', True) | map(attribute='entity_id') | first }}
      availability: |-
        | selectattr('attributes.last_called','eq',True) | first is defined }}
And if I go to Developer Tools > Template and look at what these evaluate to, there doesn’t seem to be any issues.
Input:
Output:
media_player.office_speaker
True
Calling alexa_media.update_last_called doesn’t update the value, and there doesn’t seem to be any errors in the logs.
Anyone have any idea why it would the template sensor would suddenly stop working?
Have you looked at the state in dev tools to see if media_player.office_speaker has an attribute last_called: true
EDIT: Just tried your template and it works fine for me
I found the same a while back and just replaced the notify action with this instead:
notify.alexa_media_last_called
It just notifies on the alexa that was used for the instruction
Yeah - it does.
last_called: true
last_called_timestamp: 1724864853539
Thanks! I’d still be interested if anybody knows why the custom template doesn’t work, but I will try this.
I’m getting a lots of these errors with the template, maybe AMP is dropping connection ?
Template variable warning: No first item, sequence was empty. when rendering ‘{{ expand(integration_entities(‘alexa_media’) | select(‘search’, ‘media_player’)) | selectattr(‘attributes.last_called’, ‘eq’, True) | map(attribute=‘entity_id’) | first }}’
I’m not convinced it is a AMP issue… Surely if the template is evaluating correctly in Developer Tools > Template it should also populate the entity correctly?
That sounds like a HA issue to me.
Check you are on the latest versions of both HA and AMP - I had the same issue after upgrading to HA 2024.8, as did others, and it was fixed by applying the latest update for AMP.
@richcyjafro - it certainly looks like I am. I’m on HA version 2024.8.3 and AMP version 4.12.11 which looks like the latest release on GH.
If either the notify.alexa_media_last_called or Last called sensor has been working for you over the last 9 months or so, consider yourself lucky. As I understand it, Amazon changed which actions automatically update the last_called attribute as well as how often new values are posted.
If I use notify.alexa_media_last_called on it’s own, the device that responds seems almost random. Instead I use the following, which mostly works:
  - service: alexa_media.update_last_called
    data: {}
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
  - service: notify.alexa_media_last_called
Do you have a link to the issue where this is being discussed?
This might be an issue with the availability template… If I create the template sensor again, but from the UI, it works fine with the below:
Never-mind that’s gone unavailable too now haha. Not sure what is going on.
@Didgeridrew - notify.alexa_media_last_called works, but it’s not very flexible with some more complex automations I believe. Can’t use it with media_player.play_media for example?
The notify action will not replace a media_player action, but the alexa_media.update_last_called action looks like it should update the media player entities so that the correct one is marked as last_called.
alexa_media.update_last_called is what I’m using, but the sensor is Unknown (why I started this thread) :slight_smile:
Bizarre! Your template works fine in my Dev Tools > Template.
This is my “superchargedsensor.last_alexa template.
Give it a whirl as it’s basic structure is different than yours.
  - name: Last Alexa
    unique_id: last_alexa
    icon: phu:amazon-logo
    state: >
      {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='entity_id') | first | default(none) }}
    availability: >
      {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.last_called_timestamp') | first is defined }}
    attributes:
      source_list: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.source_list') | first | default(none) }}
      is_volume_muted: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.is_volume_muted') | first | default(none) }}
      volume_level: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.volume_level') | first | default(none) }}
      media_content_type: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.media_content_type') | first | default(none) }}
      media_position_updated_at: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.media_position_updated_at') | first | default(none) }}
      source: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.source') | first | default(none) }}
      available: true
      last_called_timestamp: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.last_called_timestamp') | first | default(none) }}
      last_called_summary: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.last_called_summary') | first | default(none) }}
      connected_bluetooth: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.connected_bluetooth') | first | default(none) }}
      bluetooth_list: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.bluetooth_list') | first | default(none) }}
      actual_friendly_name: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.friendly_name') | first | default(none) }}
      supported_features: >
        {{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='attributes.supported_features') | first | default(none) }}
Correct. The http2push command PUSH_ACTIVITY stopped being issued my Amazon in early June, which is what provided near instant updating of last_called.
I’ve added an async_fire event into media_player.py at the correct point to inform me when the last_called service has actually finished so my scripts/automations can wait for that event and if it occurs, set a variable which controls executing or skipping the TTS commands in the script. I will submit a feature PR when I’m comfortable with it.
I also created this automation to update last_called whenever my Amazon Scenes/HA Scripts are executed:
alias: Alexa - update_last_called_via_scripts
description: >-
  Calls the `alexa_media.update_last_called` action whenever Alexa Scenes are
  turned on (i.e. when HA scripts are run). The scripts should begin by waiting
  for the event `alexa_last_called_updated` to fire before proceeding. If the
  event fails to fire, they should avoid using `sensor.last_alexa`.
  - platform: state
    entity_id:
      - script.bought_coffee_filters
      - script.business_trip_end
      - script.business_trip_start
      - script.feed_fish
      - script.good_morning
      - script.good_night
      - script.lights
      - script.make_coffee
      - script.may_is_coming
      - script.shower
      - script.sleep_mode
    to: "on"
condition: []
  - parallel:
      - wait_for_trigger:
          - platform: state
            entity_id:
              - sensor.last_alexa
        continue_on_timeout: false
        timeout:
          hours: 0
          minutes: 0
          seconds: 20
          milliseconds: 0
      - action: alexa_media.update_last_called
        data: {}
  - event: alexa_last_called_updated
    event_data: {}
  - action: input_boolean.turn_off
    metadata: {}
    data: {}
      entity_id: input_boolean.alexa_media_update_last_called_trigger
  - action: counter.increment
    metadata: {}
    data: {}
      entity_id:
        - counter.alexa_media_update_last_called_service_calls_today
mode: single
trace:
  stored_traces: 30
My script.good_night looks like this:
(other scripts still need editing)
Summary
alias: Good Night
sequence:
  - wait_for_trigger:
      - platform: event
        event_type: alexa_media_last_called_event
        event_data:
          summary: good night
    timeout:
      hours: 0
      minutes: 0
      seconds: 30
      milliseconds: 0
    continue_on_timeout: true
  - variables:
      alexa_last_called_updated: "{{ wait.remaining > 0 }}"
  - parallel:
      - if:
          - condition: state
            entity_id: cover.bedroom_blind
            state: open
        then:
          - data:
            action: cover.close_cover_tilt
      - continue_on_error: true
        data: {}
          entity_id:
            - input_boolean.sleep_mode
            - input_boolean.daniel_sleeping
        action: input_boolean.turn_on
          value: 0
          entity_id: input_number.bathroom_delay_off
        action: input_number.set_value
          option: Sleeping
          entity_id: input_select.sleep_status
        action: input_select.select_option
        data: {}
          area_id:
            - patio
          entity_id:
            - light.pole_lamp_1
            - light.pole_lamp_2
            - light.table_lamp_1
            - light.table_lamp_2
        action: light.turn_off
          entity_id:
            - media_player.bedroom_tv
        data: {}
        action: media_player.turn_off
      - repeat:
          count: 1
          sequence:
            - if:
                - alias: Test if {{ not wait.trigger }} renders value equal to true
                  condition: template
                  value_template: "{{ alexa_last_called_updated }}"
                - condition: state
                  entity_id: input_boolean.coffee_prepared
                  state: "off"
              then:
                    text: Did you prepare your coffee?
                    event_id: actionable_notification_coffee_prepared
                    alexa_device: "{{ states('sensor.last_alexa') }}"
                  action: script.activate_alexa_actionable_notification
            - if:
                  condition: template
                - condition: numeric_state
                  entity_id: sensor.garbage
                  below: 2
                - condition: state
                  entity_id: input_boolean.garbage_is_out
                  state: "off"
                - condition: or
                  conditions:
                    - condition: and
                      conditions:
                        - condition: state
                          state: "0"
                        - condition: time
                          before: "09:00:00"
                          after: "00:00:00"
                    - condition: and
                      conditions:
                        - condition: state
                          state: "1"
                        - condition: time
                          after: "12:00:00"
                          before: "00:00:00"
              then:
                    text: Did you put the garbage out?
                    event_id: actionable_notification_garbage_pickup
            - if:
                  condition: template
                  entity_id: sensor.recycling
                  below: 2
                - condition: state
                  entity_id: input_boolean.recycling_is_out
                  state: "off"
                - condition: or
                  conditions:
                    - condition: and
                      conditions:
                        - condition: state
                          state: "0"
                        - condition: time
                          before: "09:00:00"
                          after: "00:00:00"
                    - condition: and
                      conditions:
                        - condition: state
                          state: "1"
                        - condition: time
                          after: "12:00:00"
                          before: "00:00:00"
              then:
                    text: Did you put the recycling out?
                    event_id: actionable_notification_recycling_pickup
      - if:
          - condition: state
            entity_id: lock.patio_door_lock
            state: unlocked
        then:
          - target:
            data: {}
            action: lock.lock
  - parallel:
      - if:
          - condition: not
            conditions:
              - condition: state
                entity_id: climate.living_room
                attribute: preset_mode
                state: eco
                alias: Preset of Furnace
            alias: If Preset of Furnace is NOT  'eco'
            attribute: temperature
            above: 17
            alias: Furnace temperature is above 17
        then:
              temperature: 17
            action: climate.set_temperature
          - if:
              - alias: Test if {{ alexa_last_called_updated }} is true
                condition: template
            then:
                  message: Heat is now set to 17
                action: script.notify_alexa_media
      - if:
          - condition: state
            entity_id: lock.front_door_lock
            state: unlocked
        then:
            data: {}
              entity_id:
                - lock.front_door_lock
            action: lock.lock
          - if:
                condition: template
            then:
                  message: The front door was unlocked but I locked it for you.
      - if:
          - condition: state
            entity_id: cover.garage_door
            state: open
        then:
          - if:
              - condition: state
                entity_id: sensor.season
                state: summer
            then:
              - if:
                    condition: template
                then:
                      message: Hey. Did you know the garage door is open?
                      milliseconds: 0
            else:
              - if:
                    condition: template
                then:
                      message: I closed the garage door for you
                      milliseconds: 0
  - if:
        condition: template
    then:
      - alias: "Media Player: Say Goodnight"
          media_content_id: Alexa.GoodNight.Play
          media_content_type: sequence
          entity_id: "{{ states('sensor.last_alexa') }}"
        action: media_player.play_media
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - data:
      sequence:
        - action: light.turn_off
          data: {}
            entity_id:
              - light.nightstand_lamps
              - light.headboard_indirect
      expected_state:
        - "off"
    action: retry.actions
  - if:
      - condition: state
        entity_id: binary_sensor.bathroom_occupancy
        state: "on"
    then:
      - wait_for_trigger:
          - platform: state
            entity_id:
              - binary_sensor.bathroom_occupancy
            to: "off"
        timeout:
          hours: 0
          minutes: 1
          seconds: 30
          milliseconds: 0
  - data: {}
      entity_id: light.bathroom_light
mode: single
icon: hass:weather-night
I also had a “Woo Hoo!” moment earlier this evening after studying OpenHAB’s implementation of their version of Alexa Media Player. I think I danced around my office for like 10 minutes!!
I created a new user in HA to be used by my Amazon Alexa Smart Home Skill.
Then I disabled the skill in Alexa and re-enabled it with the new HA user account.
With that in hand, I can now update last_called in HA whenever that Amazon Alexa user account changes any HA entity state that is exposed to it via this automation:
alias: Alexa - Triggered by Smart Home Skill user account
description: >-
  Perform action `Alexa Media Player: Update Last Called Sensor` when entity
  states are changed by Alexa Smart Home Skill user account
  - platform: event
    event_type: state_changed
    context:
      user_id: 0df463c1efc4490f900b09b143cae9c4
condition: []
    data: {}
mode: single
@dbrunt - sorry I totally missed your response!
There was some weirdness, even with your version of the template entity, but backing up the configuration file, removing 90% of it, restarting, restoring it, then restarting again fixed the issue :person_shrugging:
Is this service/action supposed to actually be working now?
I tried to call it from dev tools and nothing happens. All my echo’s still show last_called as null.
Yes it’s working but only if your AMP integration is working. Enable debug for both alexapy and cutom_components.alexa_media, restart and recreate scenario and then review your full log filtered by “alexa”…
Thanks for the info.
I found a couple of typo’s tho. should be:
custom_components.alexa_media
But I did that and tried again on my media_player.livingroom_dot entity and here are the logs:
2024-09-20 19:36:05.564 DEBUG (MainThread) [custom_components.alexa_media.services] Service update_last_called for: []
2024-09-20 19:36:05.675 DEBUG (MainThread) [alexapy.alexaapi] j************7@g*******m: static GET: https://www.amazon.com/alexa-privacy/apd/rvh/customer-history-records?startTime=1726788965564&endTime=1726961765564&recordType=VOICE_HISTORY&maxRecordSize=10 returned 429:Too Many Requests:text/html
2024-09-20 19:36:05.676 INFO (MainThread) [alexapy.alexaapi] Backing off _static_request(...) for 0.0s (alexapy.errors.AlexapyTooManyRequestsError: Too Many Requests)
2024-09-20 19:36:05.788 DEBUG (MainThread) [alexapy.alexaapi] j************7@g*******m: static GET: https://www.amazon.com/alexa-privacy/apd/rvh/customer-history-records?startTime=1726788965564&endTime=1726961765564&recordType=VOICE_HISTORY&maxRecordSize=10 returned 429:Too Many Requests:text/html
2024-09-20 19:36:05.788 INFO (MainThread) [alexapy.alexaapi] Backing off _static_request(...) for 1.6s (alexapy.errors.AlexapyTooManyRequestsError: Too Many Requests)
2024-09-20 19:36:07.588 DEBUG (MainThread) [alexapy.alexaapi] j************7@g*******m: static GET: https://www.amazon.com/alexa-privacy/apd/rvh/customer-history-records?startTime=1726788965564&endTime=1726961765564&recordType=VOICE_HISTORY&maxRecordSize=10 returned 200:OK:application/json
2024-09-20 19:36:07.589 DEBUG (MainThread) [custom_components.alexa_media] j************7@g*******m: Updated last_called:
the tts actually worked for that media player so I know AMP is working as expected.
Just coming back to say that it’s working.
I was on an older version of AMP. After updating it’s good now.
:slightly_smiling_face:
