I’m assuming Amazon changed something a few days ago. I use the Cuckoo Clock script to play a local mp3 every hour/half hour on my echos.
This has always worked flawlessly, but as of 1/27 it no longer plays the audio and instead I get Alexa telling me “to play TTS, please set announce=true. Music can’t be played this way”. I’m unsure what changed our exactly how to adjust the script to correct for this
Mine is working… post the script or automation you are using and any recent traces of failed runs.
FWIW, there seems to be a widening gulf when it comes to features availability from region to region, so it may helpful if you include where you are in the world so we all know we are comparing apples to apples.
Appreciate the reply. So to start, I’m in the US. I’m not sure i can follow the traces as the automation is in yaml in a package. Included here is the contents of the package itself:
# Origianl Repo: @chrisron95 - https://raw.githubusercontent.com/chrisron95/home-assistant-config/master/packages/clock_chime.yaml
## Plays the number of cuckoos per hour and 1 on the half hour.
# More Info and Video: https://www.vcloudinfo.com/2017/11/building-digital-cuckoo-clock-with-home.html
# Modified from Chris Heder (@chrisron95) for Maison Des Lunes
# Setup package to make everything configurable.
# Added:
# - Ability to select sound between Cuckoo and Grandfather Clock
# - Quarter toll ability
# - Ability to disable quarter and half tolls, and chime entirely
# - Time helpers for start and stop times.
# Changed:
# - Now runs every 15 minutes rather than only every half hour
# - Triggers have IDs now which allows me to replace the time templates
input_boolean:
clock_chime:
icon: mdi:alarm
clock_chime_half_toll:
name: Clock Chime Half Hour Toll
icon: mdi:alarm
clock_chime_quarter_toll:
name: Clock Chime Quarter Hour Toll
icon: mdi:alarm
input_datetime:
clock_chime_on_time:
name: Clock Chime On Time
has_date: false
has_time: true
clock_chime_off_time:
name: Clock Chime Off Time
has_date: false
has_time: true
input_select:
clock_chime_sound:
name: Clock Chime Sound
options:
- Cuckoo Clock
- Grandfather Clock
icon: mdi:bell-ring
automation:
- alias: Clock Chime
mode: restart
# Trigger every 15 minutes. The ID lets you know which one is current, rather than a time template.
# This accounts for the delay when waiting for media player to stop playing, just in case it lasts too long.
- platform: time_pattern
minutes: 0
minutes: 15
minutes: 30
minutes: 45
condition:
- condition: time
after: input_datetime.clock_chime_on_time
before: input_datetime.clock_chime_off_time
- condition: state
entity_id: input_boolean.audible_notifications
state: "on"
- condition: state # Make sure the chime is enabled.
entity_id: input_boolean.clock_chime
state: "on"
- condition: or # Either we are home or Guest_Mode is on.
conditions:
- condition: state
entity_id: binary_sensor.family_home
state: "on"
- condition: state
entity_id: input_boolean.guest_mode
state: "on"
- choose:
# Check for quarter and half hour trigger, and stop if it should be disabled.
- conditions:
- condition: or
conditions:
- condition: trigger
sequence:
- condition: or
conditions:
# Don't play the quarter toll if it's disabled.
- condition: state
entity_id: input_boolean.clock_chime_quarter_toll
state: "off"
# Also don't play the quarter toll if Cuckoo Clock is selected as it's not needed.
- condition: state
entity_id: input_select.clock_chime_sound
state: Cuckoo Clock
- stop: "Quarter Toll Disabled"
- conditions:
sequence:
# Don't play the half toll if it's disabled.
- condition: state
entity_id: input_boolean.clock_chime_half_toll
state: "off"
- stop: "Half Toll Disabled"
default: []
- if:
- condition: state
entity_id: media_player.kitchen_dot
state: 'idle'
then:
- service: media_player.volume_set
volume_level: 0.25
- service: media_player.play_media
entity_id: >
media_content_id: >
{% if states("input_select.clock_chime_sound") == "Cuckoo Clock" %}
{% if trigger.id == "30" %}
https://slackerlabs.s3.amazonaws.com/audio/cuckoo/cuckoo-clock-01.mp3
{% else %}
https://slackerlabs.s3.amazonaws.com/audio/cuckoo/cuckoo-clock-{{now().strftime("%I")}}.mp3
{% endif %}
{% elif states("input_select.clock_chime_sound") == "Grandfather Clock" %}
{% if trigger.id == "15" %}
https://slackerlabs.s3.amazonaws.com/audio/gfclock/toll-1quarter.mp3
{% elif trigger.id == "30" %}
https://slackerlabs.s3.amazonaws.com/audio/gfclock/toll-2quarter.mp3
{% elif trigger.id == "45" %}
https://slackerlabs.s3.amazonaws.com/audio/gfclock/toll-3quarter.mp3
{% else %}
https://slackerlabs.s3.amazonaws.com/audio/gfclock/{{now().strftime("%I")}}-hour.mp3
{% endif %}
{% endif %}
media_content_type: music
else:
- service: script.jarvis_voice
who: kitchen
message: > # Use the trigger ID to specify which sound to play.
<audio src='https://slackerlabs.s3.amazonaws.com/audio/cuckoo/cuckoo-clock-01.mp3'/>
{% else %}
<audio src='https://slackerlabs.s3.amazonaws.com/audio/cuckoo/cuckoo-clock-{{now().strftime("%I")}}.mp3'/>
{% endif %}
<audio src='https://slackerlabs.s3.amazonaws.com/audio/gfclock/toll-1quarter.mp3'/>
<audio src='https://slackerlabs.s3.amazonaws.com/audio/gfclock/toll-2quarter.mp3'/>
<audio src='https://slackerlabs.s3.amazonaws.com/audio/gfclock/toll-3quarter.mp3'/>
{% else %}
<audio src='https://slackerlabs.s3.amazonaws.com/audio/gfclock/{{now().strftime("%I")}}-hour.mp3'/>
{% endif %}
{% endif %}
Hopefully this helps to start.
EDIT: After checking…traces seem fine. It does execute as expected, technically speaking, becuase it goes off every hour and every half hour…only instead of playing the mp3 clip, it repeats the message about ‘music can’t be played this way’
I’m actually kind of surprised that has been working for you this long… I think it was only working because the previous behavior from Alexa was to ignore it, but now it gives you the error message. And the second services call gets dumped by Alexa because she’s in the middle of reading the error message.
If you check Jeff’s original version (and the one it was based on) the media_player.play_media service call was not meant to be targeted at an Alexa device. So, all you need to do is remove the action using media_player.play_media.
I don’t remember how Jeff has script.jarvis_voice set up… it might not take multiple players for the value of who. Generally, you have to list the target players. AFAIK it will not work if targeted on Alexa’s speaker groups.
