I just updated to 2021.12.7 and Alexa Media Player stopped working right. I may have messed it up even more trying to uninstall it
After I updated HA I noticed none of my echo dot media players were showing up as entities so I checked the integration - AMP said ānot loadedā under it. I didnāt have the option to reload it, reconfigure or anything except disable or delete. So I deleted it from my integrations and then remembered itās a custom integration and probably has to be configured in HACS. So I look under HACS and its still there showing that thereās an update.
I tried to update it, restarted HA, nothing. Still there under HACS saying:
Installed version: v3.8.2
Available version: v3.8.5
So I try uninstalling it from there, restart HA, go back to HACS, still there showing as needing an update.
Iāve tried this a several times now and nothing is working, no matter what I do it still says I have version 3.8.2 and need to update it. I looked through my config to see if there were any traces of AMP that are causing it to look like its still installed but canāt find anything relating to it. Does anyone have any ideas?
I saved a snapshot before I updated HA but Iād rather not have to revert back to the old version.
Edit: I DID find the alexa media directory under custom components in my files but Iām unable to delete it.
Edit #2: I reloaded the last snapshot of HA and Iām still having the same problem. I just want AMP gone at this point.
