I am getting a seemingly innocuous log warning “/usr/local/lib/python3.8/site-packages/alexapy/alexalogin.py (WARNING) No access token found; falling back to credential login instead of oauth” for some time, not sure when it started.
I installed “Alexa smart home skill” https://www.home-assistant.io/integrations/alexa.smart_home/ about 18 months ago, and all Alexa home assistant functions have been working fine since then. About 6 months ago I added 2FA to the Alexa media player integration when prompted for login.
I have removed and reinstalled Alexa media player integration, rechecked my Alexa smart home client id and client secret are the same as shown on my aws lambda page and removed then reenabled the custom Alexa app without effect on log warning. Does anyone have idea what might be wrong. Since everything is working, I am not inclined to try to fix anything
I had the same situation. It’s basically turning on 2FA on the Amazon page. Two-Step Verification (2SV) Settings they call it. Once you have that turned on, you delete the current integration, and any reference to it in configuration.yaml, and reinstall it. There is a guide on the integration page.
Can anyone tell me how to overcome? I have over 1000 errors daily. A selection tagged below.
I have gone to great extent over the past few months with no reply.
Including a completely new install reinstalling each integration. Can anyone please help?
2022-04-27 10:18:38 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport for binary_sensor.garage_door to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
2022-04-27 10:53:33 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from ec2-18-210-7-77.compute-1.amazonaws.com (18.210.7.77). (python-urllib3/1.26.6)
2022-04-28 03:38:54 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-04-28 03:39:00 WARNING (MainThread) [alexapy.alexalogin] No access token found; falling back to credential login instead of oauth.
2022-04-28 03:39:01 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140686321616064] Received invalid command: mobile_app/push_notification_channel
2022-04-28 03:39:01 WARNING (MainThread) [alexapy.alexawebsocket] mac_dms not detected; websocket likely won't connect
2022-04-28 04:08:24 ERROR (MainThread) [frontend.js.latest.202204050] :0:0 ResizeObserver loop completed with undelivered notifications.
I have been chasing this issue longer that I can remember. Till now, no one has offered any help.
I have tried everything I can think of… Including deleting everything and re-install. This is what I call my brute-force method (Start Over). the interesting thing, and maybe you can clarify… F2A… I have about 5 various passwords for Amazon… to include what I refer to as F2A being an app on my cell phone called authy in which the code is changed every 30 seconds… The last round was painful!
But I got it operational once again, and yes, the
2022-05-17 11:21:55 WARNING (MainThread) [alexapy.alexalogin] No access token found; falling back to credential login instead of oauth.
2022-05-17 11:21:56 WARNING (MainThread) [alexapy.alexawebsocket] mac_dms not detected; websocket likely won't connect
is back taking my log hostage such that I rarely can seek out the important stuff…
Thoughts?
all I can say was I was getting the exact error that you are experiencing, until I turned on 2SV on the Amazon web page, and then reloaded they Alexa media player integration:
Till now the only thing I have is S2A with Amazon requires a code from my authy app… Every time I purchase or basically transact in any way requires that code…
Any stepped guidance would be helpful… Did I understand you have to delete everything and start over at installing again with HACS, then installation, then do the skills again?
… BTW… Thank you for taking the time. I am just so confused…
@quadhammer
Just checking to see if you are still available to assist. I have been reading various documentation and still super confused with the Configuration · custom-components/alexa_media_player Wiki · GitHub direction Step 4.
Enter the value from Step 3 I can not seem to find where I enter that value. Can you still assist?
