Alexa on your linux (inc raspberry pi)
Hi all, just thought you should be aware that you can addalexa straight on your device running home assistant, and although it’s not directly related to HA, I thought it might be good to spread the the word, the article I read was https://dzone.com/articles/how-to-add-alexa-to-a-raspberry-pi
@CaptainComedy Thanks a lot for the share :wink: Suggestions for some mic to use for it ? or some that can be used remotely ? my Raspberry is in my technical closet ! Would need Alexa in living room…
I’m guessing any multi directional usb mic into the pi would work - not sure about drivers though… that could potentially open up another can of worms :wink:
@CaptainComedy I would prefer something on network considering distances between PI and my living room and network mic would mean perhaps capability to get Alexa easily in multiple rooms !!
I would imagine that is both entirely possible and scaleable if a network mic is cheaper than an alexa :slight_smile:
That said, feedback might be difficult unless you have multiroom speakers also
Yep but use one Raspberry PI for each room I need Alexa is not the cheapest also ! What did you use as mic/speaker that fits well with PI ? and works well if possible :smiley:
@CaptainComedy Let me just add some info to your topic.
I used simplified installation of alexa on my HA raspberry - AlexaPi project.
Just for fun I also played with R2D2 voice for alexa as described on https://xubecblog.wordpress.com/2017/05/22/r2d2-assistant-with-raspberrypi/.
In case of keyword recognition problems I’d recommend to use showboy component instead of default pocketsphinx.
