"Alexa, open cover" is not supported - voice commands doesn't work
Hey,
I want to control my covers with Alexa.
This needs to be based on the room (alexa group) - like “turn on lights”.
I added the cover to the sleeping room group and when I say alexa, cover to 100% it already uses the right one - that works.
The problem is that I just want to say “cover up” or “open cover” or something like that,
but the answer is always “this command doesn’t work with the device sleeping room cover”
Works:
Alexa, Cover to 100%
Alexa, Cover to 0%
Doesn’t Work:
Alexa, close the Cover
Alexa, Cover off
Alexa, Cover on
Alexa, open Cover
The devices is exposed as Cover in the Alexa App.
Is this a limitation of Alexa or is something wrong with my config?
  covers:
    living_room_rollo:
      device_class: shutter
      friendly_name: " Wohnzimmer Rollo"
      position_template: "{{ states('sensor.living_room_rollo_position') }}"
      open_cover:
        - service: rest_command.belt_winder_up
            did: 2 # This is the Device ID also used in sensor.yaml
      close_cover:
        - service: rest_command.belt_winder_down
      stop_cover:
        - service: rest_command.belt_winder_stop
      set_cover_position:
        - service: rest_command.belt_winder_set_position
          data_template:
            position: "{{position}}"
belt_winder_up:
  url: 'http://192.168.178.79/devices/{{ did }}'
  method: PUT
  payload: '{"name":"POS_UP_CMD"}'
belt_winder_down:
  method: PUT
  payload: '{"name":"POS_DOWN_CMD"}'
belt_winder_stop:
  method: PUT
  payload: '{"name":"STOP_CMD"}'
belt_winder_set_position:
  method: PUT
  payload: '{"name":"GOTO_POS_CMD","value":"{{ 100 - float(position)|int }}"}'
Cheers!
Try
Alexa set cover to xxx%
Alexa turn on/off cover
I remember running into that a long time ago when I first integrated my garage doors. The way I do it is that I set up scripts to open and close the doors. Then in the Alexa app I set routines to call the appropriate scripts when I say “open/close the garage door”. The scripts will be exposed to the Alexa app as scenes.
“Alexa set cover to xxx%” works
“Alexa turn on / off sleeping room cover” works
but turning off and on feels sooo wrong with covers :confused:
I understand your Idea but you can’t assign a script to a room.
That means you always need to say “the sleeping room cover” or “the kitchen cover” but I wanted to just say “cover” and then the cover in the same room opens. I also just say “Alexa, turn on lights” and not “Alexa, turn on lights in sleeping room”.
But it really seems like there is no solution yet.
Any news here?
There is an easy fix. By using alexa media player you can create a sensor for the last called echo.
I created a script each to open, close and stop a cover and made a routine for each with multiple commands.
You can either do the assignment in the script echo to cover manually or do it like I do: Assign all echos and covers to areas in Home Assistant and let it match the entities automatically:
sequence:
  - service: alexa_media.update_last_called
    data: {}
  - service: cover.open_cover
    data: {}
      entity_id: >-
        {{ area_entities(area_id(states('sensor.letzter_echo'))) |
        select('match', 'cover') | list  }}
