File Path = “/usr/share/hassio/homeassistant/” ← i dont see a new file there
Error:
[node: Alexa Account](https://xxx.duckdns.org:18123/api/hassio_ingress/8uS0WnyxY8iXRozfw1Nm09z9RT_NAj1rjBqpn0UvfY0/#)msg : string[74]
"ENOENT: no such file or directory, open '/usr/share/hassio/homeassistant/'"
Enter a File Path to save the authentication result so following authentications will be automatic.
so the path in the server is used on Node red, and i should add new text file under config/node-red called amazon.txt. i did that and restarted but it’s still not working, and it keep asking my to reauthenticate every time i deploy the flow.
